BIOS ADMIN OR WINDOWS? NO OS stated at all
and Dell ships with many OS.
we can not see your screen at all
no photos of any failing screen means it can be 2 things, BIOS PW or WINDOWS PW;.
only dell can reset BIOS , we can not,
nor is it legal for me to try.
Dell.com is the maker ask them to cure this.
the windows pass words resets get harder by each newer OS, all are geek easy until windows 8 up.
no posted screen by you , NO JOY.
dell will make you prove you own the PC before telling you the reset secret.
this old PC, 12 years old today.
BIOS ADMIN lost. PW.
if you are geek like we open the left side lid, and look at the mobo, the motherboard PCB, and find pw_rst pins.
mine has many jumpers on I it.
first I replace that RTC Coin cell battery
or the BIOS will go nuts, infact so nuts the PC thinks PW is set, and is not, so
if the battery is below 2.9v then you need a new battery FIRST< as they say first things first. on any 5 year life battery,
ok the 530 comes on like 6 versions, 530 ,530a, to S
the 530 base no letter at the end.
is here.
if you read the manual at dell. the pin jumper is labeled.CLEAR_PW (bios
CECledc
the jumper is shown as jumper 12. at dell
here is the page (real dell real books)
https://downloads.dell.com/manuals/all-p...
if you question was how to reset windows 10 logins, that is a totally different answer.
we have lots of dell PCs workstations and servers here. so, can answer, on experience.
Use this tool (https://www.hirensbootcd.org/old-versions/) , bootable CD or USB, tons of tools inside including password recovery or create new Admin then reboot and using the new admin from there you can access your admin account to reset the password.
SOURCE: dell inspiron 5150 laptop, reset admin. password.
Restart your laptop and keep tapping F8 key the moment you see something on the screen. You will get a black screen with some options written in white. Select the option Safe mode and then you can create a new user with admin rights. Or else at the windows login screen press and hold ctrl and alt key and tap delete key twice and then it will take you to a login screen. Dont put any password there just hit enter. And you will be able to login with admin rights.
Thanks
Deepak
SOURCE: i have laptop Dell
WARNING: Some BIOS configurations will lock you out of the system completely if you type in an incorrect password more than 3 times. Read your manufacturers documentation for the BIOS setting before you begin typing in passwords.
Award BIOS backdoor passwords:ALFAROME BIOSTAR KDD ZAAADA
ALLy CONCAT Lkwpeter ZBAAACA
aLLy CONDO LKWPETER ZJAAADC
aLLY Condo PINT 01322222
ALLY d8on pint 589589
aPAf djonet SER 589721
_award HLT SKY_FOX 595595
AWARD_SW J64 SYXZ 598598
AWARD?SW J256 syxz
AWARD SW J262 shift + syxz
AWARD PW j332 TTPTHA
AWKWARD j322
awkward
AMI BIOS Backdoor Passwords:AMI BIOS PASSWORD HEWITT RAND
AMI?SW AMI_SW LKWPETER CONDO
Phoenix BIOS Backdoor Passwords:phoenix PHOENIX CMOS BIOS
Misc. Common PasswordsALFAROME BIOSTAR biostar biosstar
CMOS cmos LKWPETER lkwpeter
setup SETUP Syxz Wodj
Other BIOS Passwords by ManufacturerManufacturer Password
VOBIS & IBM merlin
Dell Dell
Biostar Biostar
Compaq Compaq
Enox xo11nE
Epox central
Freetech Posterie
IWill iwill
Jetway spooml
Packard Bell bell9
QDI QDI
Siemens SKY_FOX
TMC BIGO
Toshiba Toshiba
Toshiba BIOS
Most Toshiba laptops and some desktop systems will bypass the BIOS password if the left shift key is held down during boot
IBM Aptiva BIOS
Press both mouse buttons repeatedly during the boot
Using the Motherboard "Clear CMOS" Jumper or Dipswitch settings
Many motherboards feature a set of jumpers or dipswitches that will clear the CMOS and wipe all of the custom settings including BIOS passwords. The locations of these jumpers / dipswitches will vary depending on the motherboard manufacturer and ideally you should always refer to the motherboard or computer manufacturers documentation. If the documentation is unavailable, the jumpers/dipswitches can sometimes be found along the edge of the motherboard, next to the CMOS battery, or near the processor. Some manufacturers may label the jumper / dipswitch CLEAR - CLEAR CMOS - CLR - CLRPWD - PASSWD - PASSWORD - PWD. On laptop computers, the dipswitches are usually found under the keyboard or within a compartment at the bottom of the laptop.
Please remember to unplug your PC and use a grounding strip before reaching into your PC and touching the motherboard. Once you locate and rest the jumper switches, turn the computer on and check if the password has been cleared. If it has, turn the computer off and return the jumpers or dipswitches to its original position.
Removing the CMOS Battery
The CMOS settings on most systems are buffered by a small battery that is attached to the motherboard. (It looks like a small watch battery). If you unplug the PC and remove the battery for 10-15 minutes, the CMOS may reset itself and the password should be blank. (Along with any other machine specific settings, so be sure you are familiar with manually reconfiguring the BIOS settings before you do this.) Some manufacturers backup the power to the CMOS chipset by using a capacitor, so if your first attempt fails, leave the battery out (with the system unplugged) for at least 24 hours. Some batteries are actually soldered onto the motherboard making this task more difficult. Unsoldering the battery incorrectly may damage your motherboard and other components, so please don't attempt this if you are inexperienced. Another option may be to remove the CMOS chip from the motherboard for a period of time.
Note: Removing the battery to reset the CMOS will not work for all PC's, and almost all of the newer laptops store their BIOS passwords in a manner which does not require continuous power, so removing the CMOS battery may not work at all. IBM Thinkpad laptops lock the hard drive as well as the BIOS when the supervisor password is set. If you reset the BIOS password, but cannot reset the hard drive password, you may not be able to access the drive and it will remain locked, even if you place it in a new laptop. IBM Thinkpads have special jumper switches on the motherboard, and these should be used to reset the system. Also, Hirens Bot CD has Bios password crackers too. Good luck.
If this helps you resolve your problem, please
consider giving a good rating and a quick thanks
or good job.It will help me as well Thank you.
SOURCE: hi I forgot DELL
To reset the BIOS read the information from this link.
In case of your Dell laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
SOURCE: I forgot DELL INSPIRON N5110 ADMIN BIOS PASSWORD......HELP
I forgot my Dell laptop password,I use Windows Password Recovery Tool 3.0 to help me. It can help you reset forgotten or lost laptop password by creating a password reset disk with CD/DVD or USB flash drive. with this powerful Dell password cracker, you can Reset your forgotten laptop password with 3 simple steps: 1.Download 2. Burn 3. Reset
Step1: Download Windows Password Recovery Tool 3.0 in any PC.
Step 2: Burn a bootable CD/DVD/USB drive in a few seconds.
Step 3: Reset Windows password under Win PE within a few clicks.
I think it can also help you.You can get it and see the datail from http://www.windowspasswordsrecovery.com
Hi ella , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Windows PW, or Linux, or citrix or BOIS.
dell sells PC with all that and more back 12 years ago.
