Electronics - Others Logo
A
Alison Posted on Sep 23, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to rename a Kingston 4gb memory stick - Kingston Electronics - Others
Paul Bade
Level 3:
  • Master 1,818 Answers
  • Posted on Sep 03, 2020
Paul Bade
Master
Level 3:
Answers
1818
Questions
Helped
574158
Points
5816
The exact procedure depends on your operating system, but changing the volume name is usually very similar to renaming a file, e. g., in a file browser window showing the mounted drives, you would right-click on the memory stick icon and select "Rename..." from the pop-up menu, or double-click on the volume name to enable editing it. Of course, you must have write permission for the entire volume.
Note: In some OS versions, you may not be able find "recent files" opened from that volume before you renamed it; you'd have to browse directly to the memory stick instead of using the recent files shortcuts.
  • Your Consultant Sep 29, 2020
    Also note, you can't enter a name that is too long as you can on files and folders in your system. Stick to 8 or less characters.
5 Related Answers
Anonymous
  • 98 Answers
  • Posted on Mar 22, 2009
SOURCE: can't clear memory stick
I am Rob and a expert on camera repair. Please use a universal cardreader they are very cheep and helpfull to clear or format the memory from every brand.
Anonymous
  • 106 Answers
  • Posted on Jun 28, 2009
SOURCE: PSP not detecting files on a 4gb memory stick PRO Duo
There are certain folders that the PSP puts on the stick when it formats it. Format the new stick on the PSP first. Then, you can transfer you files to it.
Anonymous
  • 42 Answers
  • Posted on Jul 09, 2009
SOURCE: Misfunctioning 4GB memory stick pro duo
Are you formatting it with your computer or PSP?
  1. Push the little HOME button on the bottom left of the face of the unit.
  2. Use the arrow keys to move to the SETTINGS area, then move the up and down keys until you get to System Settings.
  3. Once you are there, click on the "X" button and scroll up and down as needed to find Format Memory Stick. Click on "X" again to select that option.
  4. The Sony PSP will now confirm that you want to reformat the memory stick (which removes every file and game save thereon, of course): choose yes and it'll format in just a few seconds.
It that doesn't work - try formatting it with your computer.
Anonymous
  • 1326 Answers
  • Posted on Oct 01, 2009
SOURCE: how to format a sony 4gb memory stick pro duo
Why do you need to format. If using on Sony products its ready to go no need to format. If needing formatting your PC will tell you so and will give you the option to do so by selecting yes to format and will do it for you.... Do not format unless prompet to do so
Anonymous
  • Posted on Jan 26, 2010
SOURCE: I need to play music from my Kingston Memory Stick to my Radio
Check the stereo's specs: 4 gb might be too much. It's possible they could limit you to 1 or 2 gb max. Many JVC stereos limit you to 2 gb, this one might, too.
1helpful
My usb shows only 1.96 mb while its orignal space is 4 gb
remember that a memory device needs space in which to operate
so a 4gb stick will have less than the 4gb storage
It is very possible that there is some memory being used that results in the 1.96 remaining
one possible solution is to read the stick and see if there is any files or folders than are required and then reformat it to get back to full memory
1helpful
4answers
How to convert 2gb sd card into 4gb
How to convert 1 or 2GB memory stick into 4GB?
Just follow the simple instructions:
Step1: Insert your memory stick in USB port
Step 2: Open the Drive increaser software folder (download the software)
Step 3: Rename the Pendrive or memorystickimage_thumb%25255b35%25255d.png?imgmax=800
image_thumb%25255b32%25255d.png?imgmax=800
Step 4: Open Drive Increaser 2 icon from the Downloaded folder.
image_thumb%25255b6%25255d.png?imgmax=800
Step 5: The opened file is asks USB drive Name. (Before enter the name first Rename the Memory stick or Pen drive). Just enter the renamed pen drive name. Ex: 2341
image_thumb%25255b16%25255d.png?imgmax=800
Step 6: After that, it will ask USB pendrive letter (Ex: H or I or J). Repeat this two times
image_thumb%25255b43%25255d.png?imgmax=800
Step 7: After Drive letter entry some process will be done with Red color like this image
image_thumb%25255b49%25255d.png?imgmax=800
Step 8: Finally it shows Done Please enter any key to done.
image_thumb%25255b56%25255d.png?imgmax=800
Now your Pen drive is 4GB
image_thumb%25255b63%25255d.png?imgmax=800
Mine is a kingston g2 4gb data traveler ,the main problem is that t is getting deteced as a drive g and when iam trying to open it prompts please insert a disk in drive g
Insert your memory stick into your USB port go to my computor and see if it has been detected, if so right click on it and use the option format, this shall clear all your stored data but it wil restore your memory stick.
Hello sir, i have 4gb kingston digital memory card.And music are copied into it that is going on .but i am getting memory card error when memory card is in camera
Check the manuals of your Camera see if it supports up 4GB of Memory. Also note that some cameras can only take a particular kind of memory card confirm that your camera supports Kingston.
My pen drive capacity is 4GB but its showing 200MB in my PC and in other pc and it is not storing more than 200 mb size file ?how to solve this and how can i re find my free space of 4 GB and i can use it?
Copy all the files from the memory-stick onto your disk-drive.
Then, open My Computer.
Right-mouse click on the icon for the memory-stick.
Choose Format.
Choose Quick-Format.
When it completes, it should show as 4GB.
Copy the files back onto the memory-stick.
2helpful
2answers
Acer Aspire 5601 4GB memory upgrade problem
Acer systems are picky about the type of memory you use.
What is your RAM Speed on the old chips compaired to the new chip
You may have to reorder the same type of speed memory
Try this website it will tell you what will work with your system
http://www.ec.kingston.com/ecom/configurator_new/mfrmod.asp?root=us&LinkBack=http://www.kingston.com
Asus 4 GB
windows xp will not show 4 gb of memory, it will support it but not show. you would need vista 64 bit to be shown the full 4gb of memory
1helpful
3answers
I have 4GB kingston pen drive that i want to use on windows 98. but i have no driver for it, how can i get these drivers?
Top Kingston Electronics - Others Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
