SOURCE: Sound through one channel only.....NAD 310 Amplifier
If swapping of left and right input sources and left and right speakers does not help...you might have a bad channel in your amp.
SOURCE: I have a Aiwa Stereo Receiver Av-D58. The sound
If I remember this model correctly, there is only 1 direct input. The remainder of the inputs are bufferred through a switching IC. It is likely that this IC is defective. Are there any other symptoms at all?
Thanks,
Dan
SOURCE: NAD 7130 FM stereo signal (on off again and again)
The contacts in the A B speaker selector switch had degraded on my NAD 7130 receiver. Distortion and signal loss would come and go. Contact cleaner and wriggling the swx knob became useless. Then, years ago I jumped the swx with small lengths of bare wire and tinned the whole thing with solder. Never had a problem since and it probably improved the receiver because it eliminated a component in the output stage that could (and did) introduce distortion.
SOURCE: Panasonic SC-HT900-problems with surround sound mode and digital input
I have the same problem with my RCN system
SOURCE: I have an Arcam AVR250
In Stereo Direct the analogue sound is directly routed to the amplifiers. In all the other ways the signal is digitized (if it ain't already) then modified digitally in a very specialized processor. In your case that processor has just died. It can't be repaired and you must replace the entire board it's soldered on to fix that - it will be expensive.
Why it has failed ? I don't know, but, since it's a processor, even the smallest electrostatic shock is enough.
