Question about KitchenAid Microwave Ovens
Kitchenaid microwave KHMS 2050 Fan works, control panel works, turntable works, all of the lights work. Yesterday the heating (and the noise that goes with it) stopped. Any thoughts?? Thanks
6ya staff
SOURCE:
Robert Hirst
  • 833 Answers
SOURCE: Goldstar Microwave
Could be the relay, an internal fuse. With the power off, open up the key panel and search for a fuse. Also, there are thermo sensors black, diameter of a dime and 3/8 inch thick with two wires. Check the fuse and replace if necessary. The thermo can be jumped out to test. Remove the wires, use a paper clip between them and tape it up. Briefly turn the unit on. Replace if it works now. The thermo is generally clamped to the wall of the oven behind the key panel. Never run without the thermo sensor.
Posted on Dec 19, 2007
MicrowaveSvc
William Miller
  • 9177 Answers
SOURCE: Over the range Goldstar microwave not working????
(If you need more help than this, please reply back with your model number)
It's probably a bad door switch or door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
If you only need a switch, you can order one from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Oct 03, 2008
MicrowaveSvc
William Miller
  • 9177 Answers
SOURCE: Microwave stopped working
to indutolia
The original problem was probably a bad turntable motor, which is pretty easy to replace.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Now I'd say you have a bad door switch (whether upper or lower depends on the model number) or a problem with the door switch mount.
This is a pretty simple problem to fix, too: http://www.microwavedisplay.com/doorsw.txt
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
to lostonisland - Your problem is different enough that it should be a separate post. Please include your brand and model number when you repost.
Posted on Dec 13, 2008
rhozel2010
romy sibug
  • 269 Answers
SOURCE: microwave won't heat. turntable works control
Hi! check the fuse that goes through the magnetron because i think it is no functioning.
Posted on Sep 12, 2009
localwonder
Michael Masters
  • 6784 Answers
SOURCE: microwave doesn't heat.
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Posted on Sep 18, 2009
KitchenAid KHMS 2050 SSS, doesn't heat up and indicates "Error Code F7, VH SMPS feedback, call for service"
Hi asoleyma,
This error code F7 from a Ktchenaid oven means that the function key is stuck on ERC. This can be fixed by having the control board (also called ERC or clock) be replaced.You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model number ready when you call.
Hope this helps.
Thank you for using FixYa.
Jan 30, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Our KitchenAid model KCMS185J55 is not heating. It lights up and the turntable works, it just won't heat. Tim Jones timmarg333@yahoo.com
I'm guessing you might mean model KCMS185JSS0, KCMS185JSS1, KCMS185JSS2, KCMS185JSS3, or KCMS185JSS5?
To allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms ("won't heat"), as well as the answers to these questions:
- When you try to microwave are the inside light, internal cooling fan and turntable all working?
- Is there any unusual noise or is it louder or quieter than normal?
We have a sound clip here of what a microwave should sound like when the cooling fan and high voltage section are working.
(A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.)
- If yours is making an odd noise, which does it sound like?
BUT If you or someone you know wants to go ahead check out the diode and magnetron, see these links:
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned looking, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though mag is bad!)
You can find links to helpful exploded view diagrams and part ordering help here.
Nov 28, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave won't heat. turntable works control
Sep 10, 2009 | General Electric Microwave Oven
KHMS 147KWH-0 TURNTABLE DOESN'T WORK
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can download Kitchenaid / Maytag / Whirlpool owner's manuals and installation instructions here.
Nov 20, 2008 | KitchenAid Microwave Ovens
Loud humming noise
If all of your door switches check out, replace the magnatron, capacitor, and diodes.
Oct 27, 2008 | KitchenAid KHMS145KSS Microwave Oven
Dacor dcm24s.light, fan, and control panel work but turntable and heat do not
Most likely the bottom door switch. Dacor units are built by Sharp and that switch is a very common problem. You'd either need to check the switch with an ohm meter or remove the cover of the switch to see if it's burned inside.
Oct 20, 2008 | Sharp R-930AK Convection/Microwave Oven
Oven dont warm food
Kitchenaid KHMS 147 HBL-1 unit does not heat. All other functions are working and it worked this morning but as of this evening it will not heat. I was thinking the fuse but would like some advice
Oct 09, 2008 | GE Microwave Ovens
Microwave oven does not heat anything. Clock, turntable, lights work. I turned the turntable off while the oven was cooking--heard a noise, now it doesn't heat anything.
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Jul 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
SPORADIC HEATING
check highvoltage crcuit ,and check fan, and turntable motor,
Oct 18, 2007 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave Ovens Logo
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Thomas F. Schneider
Jerry Greenberg
Jerry Greenberg
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
