My frigidaire frc150ff fridge light comes on but will not get cold whilst the freezer compartment is frosting up when put on max cooling with the thermostat?
SOURCE: Freezer frosted Inside, Fridge not cool
You have a defrost problem. Most likley a defrost heater if it's a side by side. If you unload the freezer so that you can get to the inside back wall, take the screws out of the inside back wall. Remove the panel from the back wall. Take a hair dryer and melt the ice that has formed behind the panel. (DO NOT USE A SHARP OBJECT TO CHIP ICE OUT) You can then see the defrost heater. If you put it back together the refrig, will work correctly for around three days. If the heaters are glass, you will be able to see if they are broken or the filliment is broken inside. If so you will need new ones. You will need the make, model number and serial number. to buy the new part.
Testimonial: "thanks"
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
SOURCE: Fridge not cooling- top freezer frosting over
Fan in freezer is running but no cold air blowing out. Freezer is cold but bottom part is not cooling.
SOURCE: Refrigerator compartment not cooling properly.
Yes The circulating fan behind the rear freezer wall is waring out. The fan with labor and material cost is around $300.00.
SOURCE: zanussi fridge compartment has stopped cooling but freezer is ok
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper)
between the freezer and fridge.The fan in the freezer blows air through
it. There is a flap you adjust with the
fridge temp. control. Make sure it's opening and closing when you adjust the
fridge temp .
OR.
If the evaporator coils behind the back panel of the freezer
are icing up because of auto defrost failure that will stop the circulation of
cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In
most newer models the timer has been replaced by an electronic control board.
If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks
and everything shuts down. The heater should now come on. If it does, replace
the timer. If it doesn't, check the heater and defrost thermostat. Turn the
timer again till everything starts back up to end the defrost cycle.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
