Calibration is required, I hope this helps, regards Jem ????
The C error message can indicate a problem with the weight measurement or a need to recalibrate the scale. Make sure that the scale is on a hard flat surface. Try stepping off the scale and back on. Make sure to stand still on the scale. If the problem continues, step onto the scale with one foot until the display lights up. Step off the scale and wait. The display should read 0.0 if the unit has been recalibrated.
Several Etekcity scale manuals are available here: https://www.etekcity.com/support/manual?_url=%2Fsupport%2Fmedia . The calibration step is usually required if the scale has been moved or turned upside down.
I hope this helps.
SOURCE: can't find instructions for Homedics digital scales SC-390
EACH BUTTON IS FOR FOUR INDIVIDUAL USER. BUTTON ALLOWS YOU TO INPUT IDEAL WEIGHT (FOUR GOAL WEIGHTS FOR FOUR INDIVIDUAL USERS). AND CALCULATE AGAINST ONE OF THE FOUR INDIVIDUAL ACTUAL WEGHTS. i AM USER 1 IN MY FAMILY. I HIT THE 1 BUTTON, WEIGHT AND MY GOAL WEIGHT COMES UP BEFORE MY ACTUAL.
SOURCE: What does the Bone Mass number mean on my digital scale?
I found this from another posting. Hope it helps.
FEMALES: age 20-29 normal= 6.2-7%
FEMALES: age 30-39 normal= 6-6.8%
FEMALES: age 40-49 normal= 5.6-6.4%
FEMALES: age 50-59 normal= 5.2-6%
FEMALES: age 60-69 normal= 4.9-5.7%
sorry no listings over age 69
My only thing now, is what it means if I am below the range.
SOURCE: New Scale out of box will not weigh correctly
Take a 5 pound bag of sugar, flour or what have you. Put it on the scale. If it is off, turn the scale so that you can check every possible place for an adjustment. Adjust and go for it!!! Good luck...Lee
SOURCE: Avery H500/L200 Avery Weighing Scales For
The zero capture is out of the 2percent tolerance so the cell is either faulty or requires zeroing. Open the unit and press the micros itch on the left of the board. The display flashes s. Press the zero key to change to flashing E. Press store to scroll to zero balance. Press semi auto tare. This captures zero without clearing the span calibration. The display will scroll around for a short period when complete press store.. Release the micro switch and scale will go thru warm up routine then display zero. Hope this helps, regs Darren.
