LG front load washer wd11029d drum paddle. The drum paddle has broken loose except for 1 final point. It looks like it may be secured by a screw. Is this correct. If so how do I access this screw. Do I need to remove entire drum assembly?
The drum paddles are screwed from the outside of the bowl. To access them, you have to completely strip the machine and remove the wash bowl. The paddles are rarely available as a spare part. You may be able to repair it or remove it. This will affect the wash action to a certain extent if you take it out. Its a big job.
Thank you Steve. Since posting question I have removed the paddle and discovered first hand just what a big job it was. WOW!!! Absolutely ridiculous. Ordered.
Ordered a new paddle online. $20. Fingers crossed it fits
Good luck. Its not an easy job.
SOURCE: stainless steel drum loose
A loose inner drum usually indicates a failed rear tub bearing. The only solution is to replace the rear half of the tub. (which contains the bearing).... You can check if the pulley nut has come loose by removing the rear panel. There is a large nut that retains the belt pulley to the shaft of the basket.
SOURCE: Dryer Paddle Loose
Take the four screws, out of the door and remove it. The front of the dryer will fold down and lift off, you will be able to see in side the dryer. If you want to lift the top remove the screws that are now exposed. Along with the brackets the top will now lift up.
This should allow you to access the tumbler.
SOURCE: removing rear light assembly on honda odyssey 2006
Yes, there is a "spear point" plastic clip that is still engaged into a socket type holder in the front outboard portion of the tail lamp assembly. Pry gently with a tape wrapped screwdriver at the front outboard corner of the assembly and the clip will release. You will then be able to see how the clip works and will be able to align and engage it first when replacing the tail lamp assembly.
-T
SOURCE: replacing the drum baffle in kenmore elite he3t front loading washers
The baffle basket, I ordered from sears for my Kenmore Elite he3t washer was a "new" design but the screw holes lined up. My baffle basket did not come with the screw either. I took out the screw from an existing baffle basket and found something close. Test it in the baffle basket before you try to install it. Be careful not to drop the screw or bit.
To replace the baffle basket. Remove top of washer using a screwdriver with a T20 torque bit. There are three screws at the rear. The top slides back about an inch and lift up. Place aside. Then you will see a hose going into the drum. Ignore the clamp, just squeeze the end going into the drum and work it out. Now you need to insert the baffle basket in the drum through the front door. It is easiest to rotate the drum so you are inserting it on the bottom. It slides in with the small end toward you and you must pull it forward. Hold the drum for leverage. Now rotate the drum so the new baffle is on top. You need to line up the screw hole and screw in a small screw. Replace the hose and top of washer.
Good Luck...
SOURCE: Remove headlight assembly from a 2001 Dodge Ram
On the upper grill side of the headlight assy. there
should be 1 or 2 push pins that hold the seal on the
headlight assy to the front of the fender. Also check
for a guide/push pin on the inner top of the assy on
the outer fender side. That should be all there is to
hold the headlight in place. Hope this helps.
