Question about Samsung Televison & Video
My samsung tv keeps turning on and off,what's the mean problem.
    New Friend:
  • 67 Answers
You may have a jammed remote power button that may appear to look normal. Take the batteries out and see if it still does it.
Have you bought anything recently around when thus started. Look for anything that has wifi, radio waves etc. The TV is picking up a signal
Posted on Sep 22, 2019
    Top Expert:
  • Samsung Master
  • 54,195 Answers
Failing power supply
6ya staff
SOURCE:
The menu keeps flashing on and off. I have turn the tv off 4 or 5 times but it still keeps flashing the light on the bottom of tv goes blue then red really fast
How old is your TV? This normally indicates a power problem. It could be any of the following: power supply on the TV, faulty power strip, faulty wall outlet, faulty circuit board inside the TV, faulty power cord/plug, bad airflow/clogged vents restricting air movement into the TV (can cause intermittent power faults),bad sensor inside TV. This is not completely inclusive by any means. It does mean that you should have it looked at. Someone knowledgeable/skilled should be able to determine the cause fairly quickly using a multimeter.
Apr 25, 2017 | Televison & Video
Won't turn. on red standby light changes to on but then goes right back red
TV won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have the Samsung FP-T5084 50" Plasma tv. I went to turn it on the other day, and it wouldn't turn on. No clicking. No red power indicator light. Nothing. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
More results from www.cnet.com
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old. ... I have an old type sony tv with the big back and the red power light keeps flashing and ...
How do you fix a television that won't turn on? - Ask.com
www.ask.com > Technology > Television & Video
Jan 03, 2016 | Televison & Video
Relay switch keeps shutting off
Hello Jamie,
Do you mean the house power relay? or is there a relay on the TV? if its the TV, and it is hooked up to a multi power outlet, try connecting it directly to the wall and see if this happens.. hope i can be of help!
Jan 05, 2014 | Samsung HLN467W 46" Rear Projection HDTV
Tv turns itself on and off
in general terms it means the microprocessor in the set is locked up, you have indicated a Samsung part number but NOT a brand and model number and those are needed to know if help can be given or not.
Dec 09, 2012 | Philips Samsung HL-N5065W1X/XAA...
My Samsung 46" smart tv keeps switching picture into dynamic when using smart hub or when changing from tv to av please help me fix this
It means your tv is in shop mode. Turn it off by pressing Info button on your remote control then follow from there.
Nov 20, 2012 | Televison & Video
My tv won't turn on. the power supply is good but the lamp light keeps blinking. Does this mean i need a new lamp
Yes,if the tv LED light indication the word "LAMP" on the tv bazel frame is lighting up or blinking.The tv old projection lamp been inside the tv like 1 1/2 or 2 years,tv been on and used daily 4 or 5 everydays?Yes,than ur tv projection lamp life are ended.Yes,than ur tv need a new projection lamp.
Apr 26, 2011 | Samsung HL61A650 TV
My 46" samsung lcd tv display keeps turning off
When it turns off, try flashlight 2 in from screen and see if you still see picture, if so then it's your inverter board is bad, you can price at shopjimmy.com or discount-merchant.com
Dec 18, 2010 | Samsung LN-R460D 46 in. LCD Television
Heard clicking sound then pictures suddenly disappear and the tv keeps turning off and on by itself
The tv have a board call the Ballast board,that help to ignite the projection lamp.Tv power on hear alot clicking.That mean the Ballast board is dead,must be replaced.
Jul 13, 2010 | Samsung HLP5085W 50" Rear Projection...
My tv turns off
Power issues (Tv True True (``````````` (``````````` 0 95250 95250 clip_image002.gif not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung True True (``````````` (``````````` 0 95250 95250 clip_image002.gif is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Jan 16, 2008 | Samsung HL-R6167W 61" HDTV
Open Questions:
Televison & Video Logo
22 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
