My logitech headset speakers works great, but the mic doesn't work in any program. I've turned up the volume, it's not muted, I've done the mic test and nothing comes through. It's a 2 prong, not usb. It's plugged in right, nothing loose. Only device available to select in audio in or out menu is Conexant HD audio. PLEASE help.
If you are running Vista, make sure that you set your mic as the default. Then check on vent settings and make sure that your output setting are set for your head set. You can then test your headset inside of the settings tab.
Have you set the mic you wish to use with your webcam as Default ?
XP Plug in your webcam or headset or mic you wish to use with your webcam Control Panel (Classic View) Open 'Sounds and Audio Devices' folder and click on the 'Volume' tab - make sure the speakers are not muted, open 'Speaker volume' and set the sliders toward the upper end. Open 'Audio' tab - make your preferred mic the default device in the 'Sound recording window' Open 'Volume' below the window to ensure the mic is not muted Click 'Apply' and 'OK' Restart your computer Configure the webcam / mic to your chat program
VISTA Plug in your webcam or headset or mic you wish to use with your webcam TEST SPEAKERS Right click on speaker icon in System Tray or from Control Panel Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC Click "Recording" tab. Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices' To set your preferred mic as default - click the mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click 'OK' Click "Levels" tab and ramp up sliders ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays
Make sure your webcam mic is set as default XP Plug in your webcam or headset or mic you wish to use with your webcam Control Panel (Classic View) Open 'Sounds and Audio Devices' folder and click on the 'Volume' tab - make sure the speakers are not muted, open 'Speaker volume' and set the sliders toward the upper end. Open 'Audio' tab - make your preferred mic the default device in the 'Sound recording window' Open 'Volume' below the window to ensure the mic is not muted Click 'Apply' and 'OK' Restart your computer Configure the webcam / mic to your chat program
Restart computer
Plug the webcam and launch the Logitech dashboard ( toolbar ) Open Settings menu ( 2 gear wheel pic ) Adjust mic to suit
You do not say what sort of mic you have - if its a built in laptop mic, a standalone mic or one built into the webcam. It would also be useful to know what your OS is and what chat program you want to use the mic in However we can generalise and hopefully put you on the right track
You need to set the mic you wish to use with the webcam as the 'Default' mic
XP Plug in your webcam or headset or mic you wish to use with your webcam Control Panel (Classic View) Open 'Sounds and Audio Devices' folder and click on the Audio tab - make your preferred mic the default device in the 'Sound recording window' Open 'Volume' below the window to ensure the mic is not muted Click 'Apply' and 'OK' Restart your computer Configure the webcam / mic to your chat program
