SOURCE: Sony KV-32HX15U Flashing standby light
did you ry to unplug from the wall for at least 3 min then plug back in if that does not work try pushing the tv button and reset at the same time on the remote for 1 min if this does not work please take it to a repair center
SOURCE: standby light flashes nine times and tv will not turn on
I had the same problem with Sony KV-32fs120 with 9 blinks. Replaced D645 and D647 on main board with 1.5A1KV diodes from Radio Shack which did the trick.
SOURCE: bush lcd tv turned itself off won't come back on
My Olevia LCD TV did the same thing. I turned off the back power switch and pulled the power cord as well. Left off for a couple of minutes and then re-connected cord and turned on main switch. I then turned on the front power switch and it come on just fine. These new sets have computer-like guts so you have to re-boot them sometimes. I hope this works for you.
SOURCE: my emerson tv standby light is on the power light flashes twice
Mine stayed in stanby mode and all I had to do was to switch the plug to a different outlet. The power strip it was on wasn't providing enough power. It worked fine for a month before I had a problem.
