While filter is out checking the coil check filter. If your filter is clogged then your restricting the air flow back to furnace creating ice up. Supply and return on demand. Don't have one then you won't get the other
Well if it's 78 then it's at least attempting to cool. Go to the front of the air handler an pull the black rubber insulation back on the bigger copper line. When the AC is in cool this line should be cold. Fairly cold if your cooling correctly. Also, if u have a stand that your unit is sitting on with an open bottom, then pull the filter out and get a flashlight and look into the bottom. If your coils look like snow white ice. Then your unit is icing up and u aren't getting the proper return. Check these two things and let us kno what u see.
Does the AC fans and compressor motors work? Is there power to the AC ?
Thermostat may be faulty
SOURCE: how do i set my temperture on my air conditioner
sounds like you could be low on charge,If you set you thermostat @ 78 degrees it should stay within 2 degrees of that and not have more then a 6-8 min cycle every 20 min.
