Question about HP Computers & Internet
Hp all-in-one opp 20-c410 can't get it to connect to internet
Haveadded wireless drivers still won't connect
  • HP Master
  • 5,317 Answers
No OS stated, windows 10? did you upgrade windows? (???)
you mean Wifi... im sure, wireless can be 5G wireless too.
so do all other things I the home work with Wifi?/?
like Cell phone and TV?
are you at home , work or startbucks? or air port?
do you have wifi router in the home?(model#)
Is it your wifi router or owned by ISP.?
do you know your wifi login credentials.?
how far are you from the wifi router, try at 6ft as test.?
or try ethernet wired. to see if your enternet connection really work.
does it even have this option?
Wireless LAN 802.11a/b/g/n/ac (1x1) and Bluetooth 4.2 M.2it must be there, and show up in device manager does it?
try here.
click detect my drivers, to get the right ones, this PC was sold with optional wifi, not JUST ONE.
use only the HP drivers OK? of still 100% HP PC use only HP drivers.
wifi is simple when it works then if not the not so simple at all.
I can't see your PC nor what Wifi systems you have
or distances from PC to router.
not me. so lots of questions asking in the blind.
https://support.hp.com/us-en/drivers/selfservice/hp-20-c400-all-in-one-desktop-pc-series/19390998/model/21447455
I like to test ethernet first.wired then if that works try wifi. (using the walk first the run rules of life)
http://www.pcdied.com/DevMan/internet.html
Posted on Sep 21, 2019
  • Anonymous Sep 21, 2019
    •Transmission standards: 1000BASE-T Gigabit Ethernet
    the side or rear of PC as RJ45 jack marked
    LAN or Etherenet us cable CAT5 to the router
    to see if that works. if yes the problem is only wifi dead in this PC
    if that fails you router or modem needs help.
    from ISP.
    try wired first, then talk, a $10 cable
    will not break the bank and proves what works and not.
SOURCE:
SOURCE: HP Pavilion dv4000- Can't connect to wireless internet
Is your chipset wireless network program taking over?
Often an internal system program will take priority when connecting to wireless networks.
Think of it like siblings who squabble over attention.
If you can find any other programs which are acting in this manner, I'd suggest telling them "do not use this when connecting" and then see if you can then use your main program.
Also - is your network secured and / or hidden? Did you reset your router? Sometimes this helps, too. =D
Posted on Mar 03, 2009
  • 400 Answers
SOURCE: Problem at no internet
no its not possible to download netcards from any where while you should just check you connection setting and try if on
Posted on Jun 23, 2009
  • 18 Answers
SOURCE: can't access internet wireles router says connected hp is a vista
If Nothing else changed in the last 2 weeks, such as a new router, or other hardware changes, AND it just started happening, I suggest you do a "system restore" to a date BEFORE the problem started.
This should correct the problem, and if you did any updates or other software installations, you will need to re install them.
Finally, one option prior to system restoring is to turn off the wireless router (unplug it) and then wait a minute. Plug back in. Then turn on your computer. You can try this first if you haven't already..
Good luck..
Posted on Apr 23, 2010
jcrowder0846
  • 470 Answers
SOURCE: my hp pavillion dv9000 won't connect to the internet via wireless or network cable
Your having driver issue's sound and Network drivers either corrupt driver missing. http://www8.hp.com/us/en/support-drivers.html input exact information needed, download them and be done.
John
Posted on Apr 16, 2012
joelwilcox
  • 1274 Answers
SOURCE: my hp dv6700 won't let me connect wireless says no drivers are installed,but I installed them?
First make sure there isn't a physical hardware switch that is turned off. second if you have some time, and don't mind hard wiring the computer for a bit, you can download teamviewer here: http://www.teamviewer.com/download/version_7x/TeamViewerQS.exeand email me the user name and password and I can remote in and take a look at the configuration.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Posted on May 15, 2012
Belkin f9k1106v1 range extender not connecting
Hi , I was also facing same problems.I have solutions please follow some steps:
1.Restart Your Main Wireless Router And Modem.
2.Now Turn Off Your Belkin Range Extender And Wait For 20 seconds (unplug From Power)
3.Please Plug Your Extender Back To Power Outlet And Restart Your Computer.
Still Having Problems?
Don't Worry Visit here for more solutions:
Belkin Range Extender Won Connect to Wireless Router TechVaidya
Dec 13, 2012 | NetGear Computers & Internet
It won't connect to internet
Is it just the wireless driver that is missing..Here is the site to auto update your computer http://www8.hp.com/us/en/support-drivers.html So connect your laptop to the router using the ethernet Click on start then right click on computer and click manage click on device manager you should see a device that is not have a driver in the network adapters Right click on the device and update driver and follow instructions.. If none of these work just use another computer and save the driver to a flash card or something Hope this works for you Please Rate
Nov 23, 2012 | Sylvania G-Netbook
Changed the display screen not can't connect to the internet says local and wireless card aren't plugged in
usually the screen has two cables that are connected to the wireless card. you won't get signal if you don't plug those in. however.. it is not recognizing your wireless card. go to device manager and check if the drivers are not installed or if the pc is not recognizing it.
right click on my computer, manage. and on the left device manager.
May 07, 2012 | HP Pavilion ze2000 Notebook
My hp pavillion dv9000 won't connect to the internet via wireless or network cable
John
Apr 16, 2012 | HP Pavilion dv9000z Notebook
I have an hp g60 laptop I can't seem to get
Go down to the bottom right of your screen and click on your internet icon. See if it says connected or not....(looks like a staircase). Some wireless lights on laptops are orange....mine is.
Mar 13, 2012 | HP Computers & Internet
My HP G60 laptop with Vista won't connect to Netgear router
Usually there are 2 types of wireless connections, 2.4 GHz and 5 GHz. Your laptop may not be able to connect to one of these connections, so it may be incompatible with your router. You can try buying a USB networking card (no more than $20). It will plug into one of your USB ports and should allow you to connect to your router. Hope this helps!
Jun 22, 2017 | NetGear N600 Wireless Dual Band Router
INTERNET NOT WORKING, WON'T PICK UP WIRELESS FOR SURE. THE LIGHT DOESN'T EVEN COME ON FOR WIRELESS. IT'S A DELL INSPIRION 1525. ANY HELP?
You sayin you download the new drivers for the wireless card? Check your device manager tab in control panel and see if the networks adapter is red or yellow. It should say what is wrong with it
Feb 15, 2012 | HP Pavilion Computers & Internet
My i phone 4 does not recognize my wireless hp printer 4500
Currently to use iPhone to use printing you need a airprint enabled printers! below is a list of them!
HP Deskjet 3050A e-AiO HP Envy e-AiO (D410) HP Photosmart Plus e-AiO (B210) HP Photosmart Premium e-AiO (C310) HP Photosmart Premium Fax e-AiO (C410) HP Photosmart e-AiO (D110) HP Photosmart Wireless e-AiO (B110)-Europe and Asia-Pacific HP Photosmart eStation (C510) HP LaserJet P1102w HP LaserJet P1606dn
there are more to this list and for information check http://support.apple.com/kb/HT4356
Sep 08, 2011 | Computers & Internet
"Opps Error"
That's Problem known as internet virus.
u do one thing format ur computer.
And install one program that's software name is adware
after that u do not have a sing le proble related to server & ataachments .
Reagrads.
Pradeep
Feb 26, 2009 | Yahoo Mail
How to hook up this printer wireless to my main computer
We cannot connect the pro l7680 printer wirelessly. Connect the printer to the router via ethernet cable and connect the desktop to the router wirelessly.
May 24, 2008 | HP Officejet Pro L7680 All-In-One Printer
Open Questions:
Computers & Internet Logo
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
