My Hotpoint TDC32 tumble dryer has started to make a strange noise whilst running. It is coming from the back of the appliance and occurs once per cycle. Is this something to do with the belt? The machine is heating up correctly.
Many thanks,
James
Sounds like bearings on your tdc32
We have made a few videos on these dryers and there are some very good repair guides on these.
if you need parts please feel free to see site or contact me with the full model number of the ID plate How-to-Repair
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair Need help fixing your appliances Need help fixing your appliances
Hi there james just check if u can move the inner drum by opening the door and place your hand on the inside with your fingers facing down if the drum moves even slightly when u pull your fingers up then it will more then likely be your bearings which are situated at the back m8
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
My Hotpoint Aquarius TCD32 0771200901
Tumble dryer stopped working, first a filter
care light, so cleaned the filter and now the light comes on but nothing
happens. Any ideas? Thanks
my tumble dryer has been on a couple of hrs and just started making a noise like something is stuck in it but i carnt see anything how can i get to look at my fan
