SOURCE: what is the gas & oil mixture for ryobi 26cc 22in hedge trimmer
If it is a 2 stroke engine, a 50:1 ratio should work. That's 50 parts gas to 1 part oil.
SOURCE: Ryobi 18V Hedge Trimmer Blade Question
Just buy a file and push 3 or 4 down strokes down the same slope of the cutter toward the sharp edge. Never file on the flat top of the cutter, only on the slope. Support the frame using a saw horse or pick-up bed. The support makes the file cut the metal better. You can do the same thing with chain saws. You just need the file that fits the cutter. You just hold a consistant angle and count out the same number of strokes. Also, clean out junk between the moving parts, tighten any loose screws, and drop a few drops of 3 in 1 oil between the moving parts. Having things sharpened at a shop is inconvenient and expensive.
SOURCE: I have a model # RY39500 ryobi hedge trimmer 2
Sounds like the air screws need adjusted on the carburator. If there are 2 the one with the L above needs to be turned althe way to the right but not to tight and then backed out 1/2 turn to left. The one with the H anove it do the same except back it out 1 and 1/4 turns to left. If it only has 1 screw dot he same but back out 2 complete turns. Hope this helps?
Ralph at [email protected]
Testimonial: "Thank you, worked great!"
SOURCE: Hedge trimmer starts fine then stops after 5 minutes
Carburetor high speed adjustment ( screw nearest the filter ) open ( counterclockwise ) 1/2 turn.
Adjust again as needed to run when hot.
make sure the gas mixture ratio is as required.
Henry
SOURCE: One year old Ryobi s430 4 stroke trimmer will not start.
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwill
need to disassemble the carburetor and spray with carb.cleaner.Make
sure the small screen is free of debris. (Should be able to seedaylight
through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
