Grilling Logo
m
mark c holstrom Posted on Sep 20, 2019
I replaced the burner tube in my go anywhere grill. it does not get very hot now old one was rusted pretty bad> when last used with rusty tube heated fine
Skylar Short
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Sep 23, 2022
Skylar Short
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
2385
Points
15
There's an orifice that you should check for glogs.
5 Related Answers
Anonymous
  • 12 Answers
  • Posted on Nov 09, 2008
SOURCE: Weber Grill
check hose for leaks using sponge soapy water . check for pinched hose. possible plug inside hose.wire brush the flame area
Anonymous
  • Posted on Jan 21, 2009
SOURCE: Ducane Grill Burner
You will need to unscrew the sides of the unit which houses the dials and ignition (This is connected to the burners). Pull it out, and they should come off rather easy if they are old. Slide them towards the front and out of the rear slots. When putting the new ones in, it is as simple as reversing what you did to take them out. You will need to go forward, into the holes, then toward the rear slots and lock them in place. You will then line up everything and screw the unit back into place. Much easier if you can get someone to help you for 10 minutes, but easily done by 1.
Anonymous
  • 109 Answers
  • Posted on Apr 03, 2009
SOURCE: Kettler tennis table has rusty legs, one is very bad
To stop this much rust - go to any hardware store and buy (I forget the exact name) a "paint" called Rust Stop. It will stop the rusting and turn the existing rust into a hard black surface that you can then paint.
Anonymous
  • 9 Answers
  • Posted on Jun 26, 2009
SOURCE: Need to replace burner tubes on a Ducane grill.
First call Weber to receive the Warrenty burners for free. Have model and serial numbers ready. They can be found on one of the doors. Here is what I did for my Ducane model 30400042.
Remove the grates and burner heat deflectors. There are 4 screws on the knob panel, 2 on the left and 2 on the right. Remove the screws and pull back about a inch or two. I found it helpful to open all the doors a bit to rest the panel on them. The burners should remove easily once this is done. Replace the burner tubes and be sure tubes have holes facing up on the one side for correct heat distribution. When placing the knob panel back on, make sure that burner tubes go onto the gas control knob correctly. Replace screws on the knob panel.
****Get a wire brush about the size of a tooth brush to clean the starter, the thing that makes the spark to start the flame.****
Anonymous
  • Posted on Sep 06, 2009
SOURCE: Ducane F7011013 FireLight II grill I am looking
I have a brand new Ducane Firelight II Camp Stove/Grill in need of a regulator/hose assembly. Would you be interested is selling me the parts from your stove? [email protected]
The flames are uneven, i have the ceramic v shaped covers fror the burners, not charcoal or rocks. the heat is all at the back, it gets very hot there and is corroding the burners and the ceramic...
What you have is a bad case of clogged burners. At least the ends closer to you. This will require removing & cleaning the burners and the venturi valves (part of each burner) to thoroughly clean them
This will also provide you a closeup inspection of all the burners for any accessive wear, or rust thru.
Once the burners are removed, use a brass bristle brush to clean the exterior of the burners and then gently yet firmly tap them on something that want damage them, Then turn them so the open end is down and any debris will fall out. Also clean the Venturi valve on each burner. It will be on the burner tube, where it fits over the burner orifice. It will look like 2 slots (1 on each side) cut out of the burner tube. Spiders like to build nest in them. After you have completed all of that, reinstall the burners, turn the gas tank back on Very, Very Slowly and give them a test. You should see a significant difference.
Hope this helps you solve the burner problem. Please let me know and Happy Grilling!!
I have my Weber Q grill hooked up to a large propane tank rather than the small tube type. It worked fine for a few weeks but now the grill only gets medium hot. Not hot enough to cook anything really. ...
Seems as if your grill is suffering from "Clogged Burner Syndrome". But, don't despair, it's easily solved by removing and thoroughly cleaning the burners or "coil" as you called it. Also, pay particular attention to the venturi valves on the open end of the burner. Spiders like to build nests in them. The venturi valve will look like a slot on the right and left of the burner tube, where it fits over the burner orifice. It's really a good idea to perform this routine maintenance, at the start of each grilling season.
When it comes to gas grills, it's like Benjamin Franklin said, "Cleanliness is next to Godliness."
Hope this helped you solve the problem. Happy Grilling!!
I am renting a condo with an old Weber Grill - 2 burner / LP (I think it is a Genesis Silver A ('00-01) model . I have very little gas pressure at the burner tubes. - Front tube flickers on/off with...
Yes the best option for just for you is to buy a new burner,tube kit and a new manifold kit because all the things that you said you removed from the burner must have caused alot of rust on the burner and if you keep welding the burner there will still be linkage after awhile so the best thing is just for u replace the burner.
Our grill won't heat above 200 degrees F. I can smell gas, but have done the soapy water test and no sign of a leak. Anything else Ishould check?
You might have the spider syndrome. A strange but common problem is that small spiders build a tiny web that blocks the gas from flowing . They find the small hole "called the orifice" that allows that gas to flow from the end of the gas hose/tube and then enter the burner. Remove the burner and look into the orifce hole; you may see a white cotten-like blockage of the orifice hole, or sometimes the web will be buily in the end of the burner tube. Either way, this is the most likely problem.. I am assuming that the burner is not old and rusting away so that the gas is not being controlled throught the burner because the burner has rust holes in it.
Charmglow grill, cannot get gas flow to multiple burners
There is no test for the regulator since they are factory set. Replace it that is your problem.
Aug 01, 2010 • Grilling
While grilling we had a flare up that quickly turned into thick black smoke rolling from our gas grill. we shut off the grill and got the flames out. what could have caused this? is it safe to try and...
If you have a grill that is several years old, some of your burners may be rusted and deteriorating, causing these large, out-of-control flames. It's definitely not safe to us in this condition. Remove the cooking grids and all parts above the burners and examine each burner with a flash light. It's also possible the seams have split which may be harder to tell that it's defective. If you can remove each individual burner to inspect it, do it and and make sure there are no restrictions inside the burner, like bug nests, debris, etc that could clog it and force gas out the venturi tube at the orifice. If you had moved or transported the grill recently before using it this last time, it may have jostled something loose or caused the rusted burners to fall apart so quickly. Hope this helps. Let me know if you need more assistance. Douglas
3helpful
Yellow flame
You may have a rusted, clogged or damaged burner or venturi tube. With a flashlight, check for spider webs, wasp nests or dirt (mud) dauber nests in the opening of the venturi tube where it connects at each gas valve orifice. Clean it out manually or blow it out with air compressor. Make sure the air adjustment opening (on the end of the burner's venturi tube) has not been changed. If it's closed too much, it will be difficult to light and cause lazy yellow flames. If it's not clogged, the burner may just be old and rusted and the burner holes are not allowing very much gas through anymore. It's also possible the burner has rusted so bad, the burner holes have been enlarged, it is falling apart or has cracks along the burner seams. If so, replace the burner(s) immediately. It is unsafe to use. Your local propane co can usually order the parts you need and some will even do the work, if you are uncomfortable doing it yourself. Bring with you the Make, Model and Serial number of the grill, so they can order the correct parts for your specific grill. Also specify whether it's natural gas2_bing.gif or propane.
Douglas
4helpful
2answers
My Weber Genesis is 11 years old
Before you go replacing things check them out. If the burner is in poor shape (holes that are rusted out) it needs replaced. You also need to replace the ventura tubes or at least clean them out. One little spider web will cause a lot of problems on a grill burner. You also need to check and see if your regulator is working at the proper pressure
MY propane grill will not come up to the 500 plus degrees for grilling.
There are four possible ways this problem could occur.
1. The unit is old and the burner tubes are plugged, either with rust or spider eggs [yes, they like it their in the winter]. Parts are available at Home Depot and Lowes.
2. The unit is designed for either Natural Gas, and you are using Propane. Conversion can be done.
3. Your gas flow is not forceful enough from the Propane tank. Could be an old tank or a bad regulator. Replace bad parts.
4. Your unit isn't getting enough oxygen because there is too much ash and grease under the grill blocking the airflow. Clean the grill.
I have a ducane stainless steel ducane 30400042. Weber has sent me new burner bars since the old ones rusted but you do I install them?
Top Grilling Experts
Paul Carew
john h
Are you a Grilling Expert? Answer questions, earn points and help others
