Question about Hardware & Accessories
Also model pt5492 sounds like it's going to come on but the timer light stays on ?
3 Suggested Answers
SOURCE:
  • 6 Answers
SOURCE: akai pt5492
This could be one of many different issues. Main flaw with these units are as follows:
Blue picture tube leaks coolant onto neck board and mainboard causing problems.
Posted on Mar 11, 2008
ahhsoo69
  • 167 Answers
SOURCE: Akai PT5492 54"
HELLO IT SOUNDS LIKE YOU HAVE A BAD FLY TRANSFORMER. . THAT NEEDS TO REPLACED. "GOOD LUCK"
Posted on Jul 27, 2008
I have a Malibu 300 watt ML300rtw, timer goes until it reaches "on" pin then stops. if i manually turn timer, i hear click and lights go on - they turn off no problem. pins are not broken. what next?
Sounds like the mechanical timer assembly likely has never been lubricated, You may use a lightweight oil, such as WD-40, to lubricate the timer mechanism.
May 09, 2015 | Malibu ML300RTW - Low Voltage Power Pack...
Parking, dash lights stay on
sounds like your relay is going out lights stay on for about three minutes then go out is normal but for them to stay on is not .make sure your dash dimmer switch is in correct position also you can before you go in turn lights on then off that will reset timer.
Jan 13, 2014 | 2002 Oldsmobile Silhouette
Akai tv model PT5492 has real bad orange tint that will not go away, with any adjusting.
it souds like your blue and green tube are getting weak and will need to be replaced
unfortunately they are no longer avail I would think about retireing that set
Dec 10, 2009 | Akai PT5492S 54" Rear Projection...
Lights continue to go off
Maybe the lights are causing photoelectric eye to sense that it's no longer dark.
This is called feedback.
To check this, set timer for 2 hours.
Put black tape over photoeye.
Check if timer turns on-and-off.
If timer continues to blink, then timer is suspect. Return it for another one.
If feedback is causing the problem, then turn timer away from lights or place obstruction between timer and lights.
Dec 10, 2008 | Intermatic Outdoor Timer/Photo Control...
Akai PT5492 54"
Jul 22, 2008 | Akai PTH5498 54" Rear Projection...
TV WILL NOT TURN OFF
Greeting inmiltown,
It sounds like your approaching the end of your lamp's life. Most projection televisions have internal lamp timers. These lamp timers usually give you time to buy a new bulb before it needs to be replaced.
I hope this helps.
Jon
Go Ahead. Use Us.
Apr 24, 2008 | Toshiba DVD Recorder AND Series2 TiVo...
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Akai pt5492
Dec 17, 2007 | Akai PT5492S 54" Rear Projection...
Hardware & Accessories Logo
29 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Thomas F. Schneider
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
