SOURCE: Blue Ray connection to Belkin G router
your wireless router is encrypted. To remove encryption, go in your computers web browser:
http://192.168.0.1
That will take you to your LAN Administrator.
Follow the simple wireless setup for an unsecured connection or setup your blue ray connection and create your own passphrase or WEPKey.
Hope that helped!
SOURCE: my Samsung Remote doesn't work with my Blue Ray
Try this advice: If it works, Great!
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12954406270641
"Dead" Remotes Can Be Saved
How to Re-Start Your "Dead" Remote Control
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck!
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote. If you do then the problem might not be the remote but the sensor on the unit.
If not, it's time to call 1-800-Remotes or use this website to order a new remote.
SOURCE: original ak59-00104r remote control device does
Take the batteries off, press the button "0" for 1 minute, put the batteries back on, try it out.
SOURCE: Does VBR120 BLU-RAY PLAYER WITH
No this model needs the ethernet connection. You can ghet a wireless router and hook it up that way if you wish. But you need to hard wire this player.
