Question about MSI Computers & Internet
I have dcore E2800 processor and want to replace it by dore E6800 processor for my msi G41-P26 board . Would it make playing pubg smoother or should I try xeon processor for my msi G41-P26 board
SOURCE:
  • 129 Answers
SOURCE: I HAVE MSI G41 Motherboard G41M-P26. MY PC
try sir first to scan your pc with a reliable and full operation anti virus, restarting pc usually is infected by virus.
Posted on Jul 11, 2011
  • 17 Answers
SOURCE: 3 SHORTBEEP CODES ON STARTUP BOARD
usually that signals a memory failure of some kind, try pulling some of your ram chips and trying different configurations.
Posted on Sep 06, 2011
  • 105 Answers
SOURCE: biostar g41 m7 wont power up after installing cpu
have you an ATX/BTX PSU?
with 24pins ATX + 4pins P4 connector?
if you haven't that it's normal that's don't work
else your PSU 5Vsb or/and your motherboard are dead
Posted on Nov 21, 2012
  • 3799 Answers
SOURCE: msi g41m-p26 won start (no power)
The most likely solution is to replace any Capacitors that have blown in the onboard power circuit. Look for a Capacitor that has got a very bulging top in the region of the power connector.
Posted on Dec 06, 2012
  • 131 Answers
SOURCE: I have a msi g41m-p26 board and it turns on but doesn't display also the lan orange light lits up as soon as I connect power and it doesn't go off
The orange light is okay. It is just telling you that the other end of the cable is connected to a device that is powered up. The light will turn green once the LAN driver are loaded.
The display not working can be any number of problems. Make sure that the cable is plugged into the right port...some systems have more than one and since only one can be active at a time if the video is plugged into the inactive one you get a blank screen. Second, make sure the screen is working. Usually if you turn it off and then back on it will display the logo of the manufacturer or something about "no signal." Most displays also have a light telling you they are on or off. Make sure it's lit up.
Now, if the display works and displays the logo when you turn it on or at least a message saying "no signal" AND if you have the cable from the video to the system connected to the right place, but you still get no video, then the problem is in the system.
To test this we usually open the system and remove everything that can be removed because it is absolutely not needed to get the system started. We disconnect the hard drive and optical drives. We disconnect any devices, including keyboard and mouse, And we remove as many expansion cards (the ones in the pci or pciExpress slots) until we get the system stripped down to it's core.
The core of the system includes the power supply, the mainboard, the cpu, one ram module and the video components....onboard if it has onboard video (which I believe it does if my memory serves me), but a video card if it does not.
Once we are at the core we test. If it works we begin to add one thing at at time, testing as we go, until we find the bad part. If it does not come on we re-seat everything and switch to a second RAM module.
Once we have re-seated the CPU and RAM, if the thing still does not work we remove the CMOS battery for five minutes, put it back and try again.
If at that point, having tested about everything you can test, if it still doesn't come up, if we have a spare CPU we change that. If that too fails to fix the problem we consider the mainboard DOA.
Hope this helps.
Posted on Feb 21, 2017
MSI G41M-P26 jpwr2? if i disconnect it no power. if i connect it there is a power but no display.
You don't give enough information. You need to decide if motherboard is starting up - and you can hear hard disk(s) running and accessing data, or if everything is totally dead.
If the former the lack of a display could be a fault with your graphics card.
You need to see if the power supply is running, look and see if its fan is going and then listen to see if hard disk motor is running. If these are dead try a replacement Power Supply.
If you get some text or graphics on the screen when you first turn on, and before screen goes blank, that suggests it is running and the blank screen can be due to a software problem.
If you need more help, supply more info about the fault.
Cheers.
May 16, 2014 | MSI G41m-p26 Desktop Motherboard - Intel...
Msi g41m-p26 won start (no power)
Dec 05, 2012 | Computers & Internet
Biostar g41 m7 wont power up after installing cpu
Nov 19, 2012 | Biostar G41-M7 Motherboard - Socket 775,...
How to reset bios on a msi g41m-p26
on the board is a jumper right above the pci slot (blue) with the pc powered off, move the jumper to pins 2 and 3, then wait 5 seconds, then move it back to 1 and 2. your bios is now reset :)
Jan 01, 2012 | Computers & Internet
I have had a motherboard failure the MS-7357 (V1.X) Mainboard... needing upgrade thinking of the MSI G41TM-E43 LGA 775 Intel G41 will i have to mess arround with the power switches with the case as this...
Boards don't come with switches. The problem with company made computers is that they get a manufacturer to make a board especially for the case they make. They do this to specifically stop you doing what you are trying to do, upgrade a machine with a proprietary board in THEIR case. You will find trouble at the rear of the machine getting to sockets and plugs.
It is far better to buy a good case, and then you can swap out components with ease. The case that held my Asus boarded P4 with the first SATA drives now has an Asus Quad Core in it with SATA 2.
MSI G41TM E43 LGA 775 Intel G41 HDMI Micro ATX Intel Motherboard Newegg ca
I would contact MSI direct
G41TM E43 MSI Global
Some of this might be useful
G33M - MSI
https://www.msi.com/Motherboard/G33M.html
... the app from the MSI website. Features - Automatically Detect the BIOS/Driver/VGA/Utility Update - Support Microsoft Windows XP/Vista/7 32/64bit. featurePic ...
::UPGRADE:: G33M (MS-7357) - new processor and RAM - MSI Forum
https://forum-en.msi.com/index.php?topic=125215.0 Mar 11, 2009 - 6 posts - ‎2 authors
The motherboard is a G33M (MS-7357) and has a piddly 1.6ghz processor and 1gb of generic RAM. I'm running Windows XP Home.
CPU-Upgrade: MSI G33M (MS-7357) processor support and ...
www.cpu-upgrade.com > MSI Nov 28, 2010 - MSI G33M (MS-7357) motherboard specifications ... FSB 200 MHz, L2 512 KB, TDP 35 Watt, Conroe-L, Rev A1, SSpec SL9XP, 7357v10.zip.
UserBenchmark: MSI G33M (MS-7357) Compatible Builds
www.userbenchmark.com/System/MSI-G33M-MS-7357/450 Compatible Components (from 7 PCs). Popular components in PC builds with the MSI G33M (MS-7357) Motherboard. CPU. Core2 Quad Q6600Intel $190Bench ...
Oct 21, 2017 | MSI G41TM-E43 LGA 775 Intel G41 HDMI Micro...
Doesn't start
hi i got biostar g31d-m7 motherboard dual core cpu 1 gb ram 500gb hard it wont boot just stucks in windows logo screen and cant even reinstall windows its just stucks in the booting logo
Oct 06, 2009 | Intel Desktop Board D845WN Motherboard
Will an Intel E7400 processor work with an MSI P965 Neo F V2?
Your processor "Intel E7400" is listed as a socket 775 Intell core 2 duo processor. Your motherboard "MSI P965 Neo F V2" is listed as an Intell board using a socket 775 processor socket. The front side buss (or fsb) speed capabilities of the mother board, and the buss speed of the processor are compatible They should play nice with each other.
Good Luck!
Jul 27, 2009 | Intel Computers & Internet
Computers & Internet Logo
16 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
