I Need a new power/invertor board for my Acer AL1711 flat panel display after it blew its fuse on the power board. I changed the fuse but its still not working.
How do I get a new board as it seems simple to replace.
Thanks
Graeme
R1 will be blown, replace it with a 10 ohm resistor. Also replace C6 and C22 with 220uf 25v Capacitors.
Did you measure yours? mine measured 4.48K - makes me think 4.7 K ohm. I wish i knew for certain before I put mine together.
Gssev: Please tell me the value of resistor R1 on this board. This is in the backlight inverter area near the 2 backlight transformers T1 & T2, just below the small green fuse F1 and just to the left of the small round coil L856. My R1 is smoked beyond recognition. Thanks.
Look in a used parts place for a dead monitor, and check if the invertor is working, replace it with a similar monitor.
