partha sarkar Posted on Sep 18, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error 062-395 xerox 560 - Xerox Office Equipment & Supplies
JMJr
Level 3:
Master:
  • Xerox Master 694 Answers
  • Posted on Jul 09, 2020
 JMJr
Xerox Master
Level 3:
Master:
Answers
694
Questions
0
Helped
166396
Points
2276
Try this link:
https://www.support.xerox.com/support/xerox-color-550-560/support/enus.html
Hi, this is 3 times in an hour that the error code 127210 appears on my XEROX color 550. HELP PLEASE Thanks
Try this link:
1helpful
2answers
Model 560. What does error code 062-395 indicate?
http://www.manuals365.com/swf/fuji+xerox/ag-c560p_c550p.html?page=207
5790. How do I correct 09-560 fault?
That is a high voltage power supply error, start by cleaning the charge scorotron and corona wires and cleaning contacts. If error persists, replace the HVPS.
3helpful
2answers
Xerox 560 error code 127-212
Error Codes
If an error caused the printing to end abnormally or a malfunction occurred in the printer, then an error message code (***-***) is displayed.
If an error code not described in the following tables is displayed, or the problem persists even after you have tried the following solutions, contact the Customer Support Center.
Tip
If an error code is displayed, all print data of the printer as well as print data stored in the built-in memory of the machine is discarded.
Error Code: 127-212
Error Category: Print; Other Problems
Cause: Detected an internal print check error by the FreeFlow
Print Services Controller.
Remedy: Remove and reinsert the command/video cable between the FreeFlow Print Services Controller and the printer. Power off and on both the printer and the FreeFlow Print Services Controller. If the problem persists, call the Customer Support Center.
*** extracted from my Fuji Xerox Color 560 Printer - Printing Systems User Guide
*** I assume we have the same printer
Phaser 560 error 73
Follow these steps :
Do power cycle
Turn the printer off, wait approximately 30 seconds and then turn the power back on.
Reseat the Imaging Unit
Unscrew the two blue screws on the Imaging Unit (one in the upper-right corner and one in the lower-left corner) and then turn the blue, bottom lever counter-clockwise 180 degrees.
Slide the Imaging Unit out of the printer half way, then firmly reseat it.
Tighten all three blue knobs so that the arrows all line up.
Check this and see if it help you else the Imaging unit will need a replacement.
Check this link for detailed steps
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=371,E=0000000002358180192,K=6211,Sxi=1,Case=obj(12762)
2answers
Dc12 error code 15-560
It's either the drum unit or the fuser from what i remember. Either way you do need a xerox technician to confirm and replace.
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
