Car Audio & Video Logo
J
John Kingston Posted on Sep 18, 2019
I have a pioneer TS-wx100bpa Amp which does not have an harness would like to know where I can purchase a harness
Jonathan Shaw
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 2 Answers
  • Posted on Dec 27, 2021
Jonathan Shaw
Contributor
Level 1:
Welcome Back:
Answers
Questions
0
Helped
500
Points
I just checked and eBay doesn't have that exact item, but could probably use one of the ones on there. They run $17-20
5 Related Answers
Anonymous
  • 944 Answers
  • Posted on Mar 09, 2007
SOURCE: pioneer ts w33c
Recommended volume for these speakers is 1-2 cu ft each speaker. Best materials are marine grade plywood and epoxy resin/matting. decide what space you think you can spare and see if you can make a box that will be about the right size in the space. always try and leave as much space behind the speaker as the speaker takes up from the front. look at the link below for some ideas of the ready made boxes you can buy. http://www.pioneerelectronics.com/pna/v3/pg/album/compare/0,,2076_310069931,00.html the speakers you have will need at least 2 one inch ports each in the back of the box, or equivalent. completely sealed can have bad effects on these speakers at high volume. I personally recommend keeping both subs in a seperate box completely, but a good solid box with a divider will probably work - make sure that no holes of any size exist between the two as this will cause distortion with certain channel set ups and is best avoided although some good results have been achieved with back flow between sub sets - it is a bit too hit and miss to be worth trying. If you need ideas how to fit these into your car so they look good - check out http://www.mtv.com/ontv/dyn/pimp_my_ride if you haven't seen it, check out a few episodes and you will get some great ideas and construction tips. Hope this helps :)
Duncan
Mike Duncan
  • 219 Answers
  • Posted on Mar 27, 2008
SOURCE: 2 Subs running together
If they have the same impedence (like 4 ohm) then you should be able to run two different model number speakers as if they were the same model number. There might be a slight difference in the way they sound, but I would not expect it to be enough to be noticeable. Good luck.
Anonymous
  • 84 Answers
  • Posted on Jun 14, 2009
SOURCE: connection Pioneer TS-W65A
you are probably looking at a dual voice coil subwoofer. This means you have many options of wiring in series/parralel/or bridged parralel. Go to either www.the12volt.com or crutchfield's learning center in order to figure out what your options are. Then you need to find out what ohm your subwoofers and what ohm your amp is stable at.
Anonymous
  • 105 Answers
  • Posted on Jul 13, 2009
SOURCE: Pioneer TS-W31C car speakers
i would recommend 12awg speaker wire
Anonymous
  • Posted on May 14, 2012
SOURCE: what amp to use for two pioneer ts-w307d4 car subwoofers
Just get 2pi amp pros at1200 watts. That way u have full control of the bass u need. Just remember to turn the amps down the subs are a little under rated. Done this myself and it is a great sous. There not a good pro sub but they will do the job in a mid size car
Purchased Pioneer FX52OUI radio and want to know is there a connector to go from the original radio connector to the new radio for a 2001 Toyota Camry XLE
You can pick up a harness at walmart. You have to wire your radio harness to the new harness then just plug it in. Here is a link to the harness kit.
https://www.walmart.com/ip/TOYOTA-1987-2001-CAMRY-CAR-CD-STEREO-RECEIVER-DASH-INSTALL-MOUNTING-KIT-WIRE-HARNESS/184805355?wmlspartner=wlpa&selectedSellerId=451&adid=22222222227059110156&wmlspartner=wmtlabs&wl0=&wl1=g&wl2=c&wl3=163044399336&wl4=pla-268921411347&wl5=9010850&wl6=&wl7=&wl8=&wl9=pla&wl10=113137261&wl11=online&wl12=184805355&wl13=&veh=sem
What would be the best amp for the money to push 4 pioneer 6.5 i door spea kers n in my truck? they are pioneer ts-a1674r. 6.5 '..3-way 300W max and 35W nominal.
i would get me a 400 watt pioneer amp that ran the same ohms as my speakers maybe a 500 watt to much power on 6.5 will pop them dont ever goby max power its to much for them
What amp to use for two pioneer ts-w307d4 car subwoofers
I have a pair of pioneer ts A-6987 connected through an amplifier and pioneer cd player..i noticed today that the left speaker's cone woofer stopped working whereas the its producing voice but if very low...
double check the ratings on the speakers and amp. speakers that size don't usually require an amp. compare the wattage and resistance numbers, if you haven't fried an amp, you may have blown a speaker. another possibility is a short in the channel. check wiring connections.
Is the pioneer ts-a6815 a good replacement for stock 2009 premium sound system?
Depends on the manufacturer of the premium sound system.I replaced my premium stereo(JBL) with pioneer mids and highs and yea they were a heck of a lot louder and the sound was like brighter and better all around but i put in a new deck and had a amp running them so i dont know if that helps you.
1helpful
I have the pioneer sub and a sony 600watt 4
it has a detector that kicks in it will usually shut off your amp and it keeps you from blowing your amp the speaker may have to much power and amp may not push it it will start to protect itself
2helpful
Connection Pioneer TS-W65A
How do i hook it up
On the Sub you have 4 connectors, 2 for each voice coil... Run a jumper wire from One side of the sub to the other. Positive to negative so that now you have one set of connectors free. Doing this will make the sub able to handle more cause you're using both voice coils. Thats how i've always hooked mine up when i have duel voice coil and they always last a long time. If you're gonna bridge the amp, make sure its turned down for about 5 or 6 hours to let the sub break in.
Top Pioneer Car Audio & Video Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
