I am in Oakleigh, suburban Melbourne, Australia.
Try https://www.microfasteners.com.au at Tullamarine
or maybe
http://costlessbolts.com.au in moorabbin
SOURCE: tower fan 07586 parts (screws)
I have an Aloahbreeze Tower Fan. The remote control does not work,I put new batteries in and it still does not work. I am disabled and need the remote. It was a gift, as I have no income, so I cannot buy a new Tower Fa. Thank you, Sheila Pike Model No. 84001(FZ25-)
SOURCE: need screw specs to attach base assy to tv
I
Hi there, if you are trying to just remove the base, then on your model there is one screw in the center of the underside of the base. If you want to remove the neck of the base to then remove the 8 screws on the back of the tvs neck too. I hoped this helped, please rate thank you!
SOURCE: need screws to put baby bed back together (lost previous screws)
i have a simmions crib and lost the screws and now i need the bed where can i get screws from
SOURCE: I cant remove the base
Hi. On the back panel just above the inputs and in the centre of the unit you will see 5 X phillips head screws (4 in a square pattern and 1 in the center of these). If you remove these screws completely the base will withdraw from the unit. Note that the washers will be a tight fit when removing and only just fit through the rear panel so use a magnetic driver or blue tack to help. Cheers. Slavious.
SOURCE: Lost my Vizio VO42L base stand screws (8). Can I
The exact size for this and almost all visio TVs are:
M4 x 35mm at .70 pitch
Hope this Helps the next guy/gal that looses their screws...
