Question about Oracle Computers & Internet
My breville oracle touch just came up with an error ER15
My breville oracle when grinding it doesnt stop automaticaly and the grinding overflows putting to much coffee
don't use automatic mode, keep an eye on it, and when full, press the 'off' button.
or clean the sensor, or
get a new one.
Sep 13, 2018 | Breville Coffee Makers & Espresso Machines
Roland Camm-1 CX-24 Error Er15:RS-232Err How do I fix this? Thanks John
Could you let us know when this error pops up. and what all you have tried
Thanks
proton
Aug 02, 2008 | Computers & Internet
How can I make the coffee not so strong tasting when using the Breville Oracle?
Adjust water (more) and bean quantities (less), see here: http://brevilleusasupport.com/bes980xl/care-and-use/menu-functions/
Mar 10, 2015 | Breville Coffee Makers & Espresso Machines
Orcale problem ?
This is an Error generated by the Oracle Client when the Oracle Server can not be reached.
This error can be caused by several items:
The Listener on the Oracle Server is not running. Check with an Oracle Administrator
The Oracle Server is off line. Check with an Oracle Administrator
The network connection to the Oracle server is not fully up and running. Check all connection points between the Notes server and the Oracle Server
A firewall exists between the Notes Server and the Oracle Server, and is not configured to allow access to both the Oracle Server's IP address and Port
The ADDRESS Parameter in the TNSNAMES.ORA file is incorrect. Use TNSPING (or TNSPING80 on Oracle 8.0.x) to check the connection to the Oracle Server. Example of a successful connection:
D:\ORANT\BIN>tnsping80 oracle
TNS Ping Utility for 32-bit Windows: Version 8.0.5.0.0 - Production on 23-APR-99
10:24:39
Attempting to contact (ADDRESS=(PROTOCOL=TCP)(HOST=DBSERVER)(PORT=1521))
OK (50 msec)
If this is Not successful, check your Oracle Network Products Messages Manual to resolve the errors that TNSPING points out.
well i found this from one site .... hope u can read it and can solve your problem
Oct 14, 2009 | Computers & Internet
Strtdb80.exe
First goto "X:\Program Files\Oracle" -> find and run Universal Uninstaller
OR
*Search and Delete all Oracle entries in the registry and then delete "X:\Program Files\Oracle"
Quote: HKEY_LOCAL_MACHINE\SOFTWARE\ORACLE
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSeT\Servic es\EventLog\Application\Oracle.oracle * Delete
X:\Documents and Settings\All Users\Start Menu\Programs\Oracle - OraHome80"
*Start->Run->Services.msc and see if any Oracle services are running then disable it. Then find and delete the services entry from registry:
HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Services
Regards,
Mar 27, 2009 | Microsoft Windows XP Professional SP2
I didn't know how to uninstall oracle 10g enterprise edition.
Dear sir
Please do the following.
start>run> ( please type services.msc)
in services window you can find some oracle services.
please stop all the services by right clicking.
after that you can uninstall the oracle software.
again you can reinstall the oracle.
please vote.
regards
murali
Feb 15, 2009 | Oracle Database 10g
Oracle 10g Error
You're using the wrong password.
Sep 10, 2008 | Oracle 10g Database Standard (ODBSEONUPP0)
Oracle Error
if it occurs after imported, it's because ctx'preferences was not imported. Try to get preferences from source (by reverse engeneriing or see with ctx_report.create_index_script package).
You will get severals scripts to execute on target db
Sep 08, 2008 | Oracle 10g Database Standard (ODBSEONUPP0)
You didn't say what machine it is, and you didn't say what OS you're running on it, or in which context it gave the error. Is this a BIOS screen error? In that case you'd look up the answer in a Peter Norton guide to PCs or such. Seriously, it's in the PC Desktops list and I'm suspecting it's actually a printer you're talking about. Get your story straight and (after studying up as much as you can on your own) put your question or success story up in the right category.
Computers & Internet Logo
18 people viewed this question
Top Oracle Computers & Internet Experts
Poul Brinchs Larsen
STEVE
JonSnell Electronic
JonSnell Electronic
Are you an Oracle Computer and Internet Expert? Answer questions, earn points and help others
