Question about Radio Communications
I have a Connex-CX 366-CE Night Runner CB radio that has just suddenly stopped getting out when i key the Mic. the needle drops to 0, but I can hear myself on the TB turned on and the RB beeps when i key it too, but I can get out to nobody. But i can receive just fine. What could it be?
    Sergeant:
  • 204 Answers
The overall reports on this radio, which appears to have been discontinued, is that it has a number of problems and needs to be serviced and the circuits aligned by someone with the appropriate skills and equipment. If you purchased it recently, from all reports, see if you can get it serviced under warranty.
otherwise, find a good CB repair shop and have them check it. The likely culprit is a bad transmit circuit. Not a easy fix unless you have the tools to test properly.
Posted on Sep 24, 2019
SOURCE:
  • 197 Answers
SOURCE: how do i find the FM frequency for a Connex
FM is just a form of modulation, not an actual frequency. The frequency doesn't change between any of the modes (LSB, USB, AM, FM, CW).
For example, if you are on channel 19 (27.185MHz) on AM (Amplitude Modulation,) switching to FM (Frequency Modulation) mode you would still be at 27.185MHz, but using a different form of modulation.
Posted on Nov 13, 2009
  • 20 Answers
SOURCE: Connex 4600 Turbo
Every tech. knows and every Connex owner Knows that once a Connex has been peaked and tuned and also had any mods done to it that the stock microphone that comes with it will not work as it should and then you will have bad feed back!! The best solution for this is buy a good Noise canceling microphone!! Such as an RK-56 or an Astatic 636-L Noice canceling microphone!! This usually will correct most of tghe feedback if not all of it!! And it will also let you keep most of your Mic gain turned uo too.
Posted on Jan 16, 2010
schast
  • 56 Answers
SOURCE: My friend would like to purchase a Connex CX 3400
These radios are know as what's called 'export' radios. They are imported under the auspices of being a 10 Meter Amateur radio and then through a typically easy modification are made to allow the selection of US CB channels. usually the modification involves plugging in a loose connector inside the radio radio chassis and/or removing a jumper wire soldered to a circuit board. If there is a nearby CB Shop they will usually do this for a modest fee.
Keep in mind that a radio needs to be Type Accepted by the FCC to be legal to use on the CB band in the US and export radios typically are not. Be sure to check the rear label for an FCC ID number.
Posted on Feb 12, 2010
Testimonial: "Thank you so much for the feedback. "
  • 219 Answers
SOURCE: Can't talk to anybody, but can hear them just fine.
Could be a few things.One as simple as a bad soilder on the board or your voltage regulator could have went out. If you take the top cover off and talk in the mic and its starts transmitting then you have a bad soilder to check the regulator is a little harder and not for just anyone to do.
Posted on May 08, 2010
  • 1274 Answers
SOURCE: cb transmit noise
Its just RF feed back, that's normal, try to re-route the coax, or just turn the FM down, o try turning your modulation down....hope this was helpful....
Posted on May 29, 2010
Keys up monentarly when radio is turned on
check the power switch contacts {ie do you get 13.8v at power on or after its fized a bit??? or roger bleep
pa circuit can do this also
Nov 20, 2014 | Connex CX-4300HP CB Radio
Plugged in heard talk then nothing lights still worked but no power signal. help
probably sent enough power thru the reverse polarity diode to burd it but still have enough to keep lights on.
Jun 28, 2014 | Connex Cx-366ce Night Runner 40ch Cb...
I have a cx-366ce cb cannot hear talking what is wrong
Is squelch turned too high that it is blocking too many signals?
Otherwise, it could be a faulty cable on the mic as the PTT button disconnects the speaker on the CB and a broken wire can cause the speaker to be disconnected.
Wire 4 pin turner plus three mic up
pin 1 gnd
pin 2 audio
pin 3 tx
pin 4 rx
Dec 24, 2012 | Connex CX-4300HP CB Radio
1 mile range on cb
Check cables and connectors.
• check antenna SWR,
A good SWR ranges from 1.2 to 1.5.
• check power output.
Jul 27, 2012 | Connex Cx-366ce Night Runner 40ch Cb...
Problems with adio not loud enough nobody hears no power
Does the needle move when you key? Is the MIC gain all the way to the right? I pose these as questions because there was not enough info....
Feb 15, 2010 | Connex CX-4300HP CB Radio
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
