Question about GE Washing Machines
My GE MODEL # GDT605PSMOSS beeps 3 times when I push the start button and doesn’t start the wash cycle. While this is happening the lock light is flashing as is the start light. The rest of the cycle lights are solid
SOURCE:
SOURCE: start flashes and will not begin wash cycle
My dishwasher Model is 665 15891790 and the serie #FG3907905. After programing my dishwasher and pressing the start button, it fills with water, but when it is due to start the sensing light comes on. I have notice that the ring under the watering arm on the bottom of the machine seams to be cracked. Could that be the problem for the machine not starting its' cycle. Thank you.
Posted on Jun 05, 2007
SOURCE: beeping
Thanks! I found this online, which shows how to run tests on the washer to see what might be wrong, which helped, too. Now if i can just find a few muscly people to help me move the dryer from atop the washer.
http://forum.appliancepartspros.com/attachments/washer-repair/42d1194897506-error-code-01-wfk2401test.pdf
from this page:
http://forum.appliancepartspros.com/washer-repair/2385-error-code-01-a.html
Posted on Nov 26, 2007
SOURCE: Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
Posted on Aug 19, 2008
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Posted on Apr 18, 2009
  • 3 Answers
SOURCE: GE washing macine stops during the wash cycle
This is exactly what my machine was doing, as well. I fixed it by cleaning out the filter in front of the water pump.
Searching here, I found that you can remove the lower front panel (three screws along the bottom edge is all it takes) to get to the filter. With the panel removed, you'll see a round white plastic cover (about 3-4 inches diameter) that screws out. Get a bucket under the cover to catch the water that's in it (could be 2 quarts or more) and unscrew the cover.
The cover pulls out, revealing that is actually a screw-in plastic strainer. I found tons of coins, broken pens, paper clips, etc. in mine when I did this. A lot will be deep inside the black rubber hose that connects this filter housing to the washer drum. You can rake the stuff out with a bent wire clothes hanger. Shaking the black hose will help hurry the junk along and out of your machine. Screw the cover back on after the clean out and your machine should go back to normal.
Thinking about it, front loaders will have lots of small items flushed into the pump compared to top loaders. Coins you alway found in the bottom of the drum in a top loader, they all wind up in the filter of a front loader. And once it slow the drainage to a crawl the machine will shut down multiple times when it can't drain the water out completely, and it will never step up to it's max spin speed with all that water still in the drum.
Posted on Nov 30, 2009
My machine is stuck on 'lid lock'.
Good day, I will see if I could assist, there is could be a few reasons this is happening. If you could list the order and sequence of the led lights please.
Code 49 is not always the inlet valves it could be the controller too, a bit of testing on your end is necessary to eliminate the actual cause and remedial suggestions.
Jun 27, 2014 | Fisher and Paykel Washing Machines
GE WCVH6800 Pressing start results in two short beeps. The pause/start button keeps blinking and it will not start a cycle.
Is the door lock button on, but the door not actually locked? Our door lock switch keeps going out. We have replaced it 4 times in the last 3 years.
Jan 16, 2011 | GE WSXH208A Front Load Washer
After the wash cycle dishwasher beeps
Hello, welcome to FixYa. While I don't have access to my PC files at the moment as I am on my iphone, I believe this is the procedure for most B/S/H/ built dishwashers ( that means Bosch, Thermador, Siemens and Gaggenau ). To Enable or Disable the Cycle Completion Signal... 1. Open the door, hold down the ?Quick Wash? button and simultaneously turn the Dishwasher on. The ?Quick Wash? light will blink (program mode). 2. While the light is still blinking, push the ?Quick Wash? button. ? If the machine beeps, then the Cycle Completion Signal has been enabled. ? When you push the button again and it doesn?t beep, it means that the Cycle Completion Signal has been disabled. 3. Turn the Dishwasher off to take it out of program mode. I hope this answer's your question. Thank you for choosing "fixya". Please rate the solution favorably if indeed it was helpful, if not please let me know. Good luck. macmarkus :)
Jul 13, 2010 | Bosch 24 in. SHV4303 Built-in Dishwasher
Beep's incessantly after cycle is complete. How can we re-program it to turn off after one or two beeps?
Hello, welcome to fixya.
1. Open the door, hold down the “Quick Wash”
The “Quick Wash” light will blink (program mode).
2. While the light is still blinking, push the “Quick
Wash” button.
• If the machine beeps, then the Cycle
• When you push the button again and it
doesn’t beep, it means that the Cycle
program mode.
Good luck.
macmarkus :)
Jun 28, 2010 | Bosch SHU9915UC Dishwasher
My washer will not start. I press the start/pause button and it just beeps twice and does not lock door or start wash. ge adora model wcvh6260
clean the drain filter located behind the front lower panell, its prob. holding excess h2o and wont let the water fill cycle activate. this happened to mine.
Aug 11, 2009 | GE Energy Star WCVH6260F Front Load Washer
Lid lock stays on and constant beep on excellence washing machine
i have the problem when i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps please help
May 26, 2008 | Fisher and Paykel IWL12 Top Load Washer
May 18, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Ge quiet power 3 dishwasher
According to the GE repairman who visited, the solution is to close the machine (with the lights flashing). The machine starts and goes through the cycles, which it does rapidly and then all the lights turn off and the machine becomes silent after 1-1/2 to 2 minutes. Then the machine has been reset to normal. During this reseting period nothing happens inside the machine, although you may hear a running sound.
Thus, the solution is to run the machine in this flashing light state for the 1-2 minutes it takes to go raipdly through each cycle and then reset.
I hope this helps.
Oct 09, 2007 | General Electric Adora GHDA670N Built-in...
Washing Machines Logo
55 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
