Question about Premier Kitchen Ranges
How to remove bottom panel on peerless premier electric range range 774m
Need to find parts for Braun gas 24in range
Barb could not find any info on Braun gas range. Check the attached links to see if they have your part. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.repairclinic.com/Shop-For-Parts/a13/Range-Stove-Oven-Parts
Purchase Range Parts for your Peerless Premier Appliance
Range Parts Range Repair Parts
Apr 21, 2016 | Kitchen Ranges
We want to remove the shower unit. its a single handle unit. how to remove from the front? there is no screw holding the handle.
Look on the bottom side of handle and see if there is a allen head set screw. Loosen screw and you should be able to remove the handle, Thank you.
Nov 22, 2010 | Peerless Industries Peerless& Single...
I need to remove the oven element. the plate that holds it appears to be riveted in place not screwed, unless screws are just worn (17 year old premier chef coordinate series).
These are screws you see. They are oxidized and the slots in the head are probably gone. Best approach is to spray with Pam (or equivalent) cooking oil, then use vise grips to remove the screws.
May 27, 2009 | Premiere Ranges EAK220 Electric Kitchen...
Oven will not light
hi thanks for the question. the part that's causing the problem is the bottom igniter. it lights up, but not hot enough to ignite the gas. replace, the igniter. thanks the appliance doc
Oct 06, 2008 | Premiere Ranges SCK3XR Gas Kitchen Range
Premier Pro•Series 36" Model P36S318BP
Sounds like you have shorted out the ignitor module and you may need to replace it. Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into. Hope this helps.
Sep 17, 2007 | Premiere Ranges P36S328BP Stainless Steel...
Jenn-Air Electric stovetop / oven range SCE4340B - Fuse blown ? ? ?
Andy, sounds like you lost a leg of power. Check the breaker box first. Maybe the contractors tapped an existing breaker instead of adding one for the burner/broiler. You would have to check the terminal block on the range. Should read 120V from each end to center and 220V across the two outer terminals. If you don't have this, something got messed up with the contractors. Catriver..post back
Mar 04, 2007 | Jenn-Air JED8430 Electric Cooktop
Premier P36S328BP: Brand New
To my opinion, the gap you have between door and gasket should not effect ranger's performance. You will have an access to the hinge by opening ranger's side panel. If I understand well,it's a new ranger.If so,in case you are insist to fix it, just call for Premiere's service for it. Good luck !!
Jun 04, 2006 | Premiere Ranges P36S328BP Stainless Steel...
Kitchen Ranges Logo
26 people viewed this question
Top Premier Kitchen Ranges Experts
Paul Carew
ray gallant
ray gallant
tmaree
tmaree
Are you a Premier Kitchen Range Expert? Answer questions, earn points and help others
