Garden Logo
David Taylor Posted on Sep 17, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replace the hose on my greenworks pressure washer
Daniel Gannon
Level 2:
New Friend:
  • Expert 66 Answers
  • Posted on Sep 28, 2019
Daniel Gannon
Expert
Level 2:
New Friend:
Answers
66
Questions
Helped
35567
Points
170
Take the bad one to either a big auto parts, tractor parts, or hydraulic hose dealer
4 Related Answers
irtlmn
Behind_Blue_Eyes
  • 1727 Answers
  • Posted on Oct 26, 2014
SOURCE: Greenworks pressure washer 1700psi 1.4. In the
does it have
oil
fuel
spark
air
rodsageek
Rodney Schmidt
  • 240 Answers
  • Posted on Jun 02, 2016
SOURCE: how to get detergent to feed into Greenworks 1700 psi washer
In addition to the comment above regarding the need to use a low pressure (soap) tip, there's a chance the tanks or the hoses from the tanks to the valve and/or from the valve to the pump is plugged with dried detergent. The easiest way to clean out the hoses, unless you can see the plug with the detergent bottle removed, is to remove the top cover and pull all the hoses and flush them out. Removing the cover is not too bad. There are several recessed screws underneath, including a couple above the wheels that requires removing the wheels and axle.
Bill Boyd
  • 53816 Answers
  • Posted on Jul 13, 2017
SOURCE: How to add oil to my greenworks 1700 pressure washer model#gws293
if electric , you don't add oil and if petrol , put in through the filler plug
Lisa Whitaker
  • 26 Answers
  • Posted on Dec 29, 2017
SOURCE: Need wand for greenworks 23 bpm pressure washer, where can I get one?
Lowes and northern tool both sell replacement wands
I have a 1700 PSI Greenworks pressure washer it leaks only when I hit the hit the one what is the problem
that selection must cause too much internal pressure for certain parts of your device to handle so the leak occur to ....let off a little pressure. Please work with Greenworks to find out whether you need to replace a part of your device to overcome the leak. Their number is 1-888-909-6757.
Thank you.
Oct 19, 2022 • Psi Garden
1helpful
2answers
How to get detergent to feed into Greenworks 1700 psi washer
2answers
I need to replace the high pressure hose on my Greenworks 1700 because the one I have has developed a hole after being in storage/no use for a few months. I purchased a replacement hose at Lowe&a
Search Fixya with your question as it was answered last June.
If less than a year old contact the manufacturer. My hose burst (different brand); turns out they got a bad batch of hoses and they replaced the whole unit at no cost.
Install high pressure hose. Cannot get shaft of hose fitting to go deep enough into fitting so retaining clip will engage
There are several different configurations for these fittings. If you bought a generic replacement hose, it may have a different fitting than what is on the machine. May have to replace the fitting on the machine, or buy a hose specific to your pressure washer.
1helpful
Install replacement high pressure hose
If you are replacing the hose because it burst you might contact the manufacturer. Mine, of a different brand, burst and they sent me a new pressure washer saying that it was very difficult to install a new hose. They had a lot of problems with hoses from China.
1helpful
How do you take the hose reel off on a greenworks 1700 psi pressure washer?
There should be a clip that holds it in place, see link.
http://www.ppe-pressure-washer-parts.com/greenworks-51012-pressure-washer-parts
Top Garden Experts
Jay Finke
Jay Finke
john h
