Question about Bose Audio Players & Recorders
Bose mini Bluetooth speaker pairs but does not connect to computer
SOURCE:
  • 233 Answers
SOURCE: Art *** does not pair with my Mac
Is this device Mac compatible? It doesn't sound like it is. Maybe go to Apple or Mfgs. website and see if drivers are available for Mac. If not, the thing will probably never work with a Mac. I always make sure hardware is Mac compatible before I buy.
Posted on Jan 05, 2009
SOURCE: paired with my laptop but no sound comes out of the speaker. my laptop still plays throuugh its own speakers.
Although I have a different model, I was having the same problem. By right clicking on the speaker icon next to the clock in the icon tray you'll get different options. Click on 'Playback Devices' and then you'll see all the speakers that are active. In my case, the default speaker was set to be my laptop speakers (you can see this because of the green dot). By simply changing the bluetooth speaker to be your default speaker (by right clicking on it) you'll hear sound again. And when the blueetooth speaker is disconnected, the laptop use your 'secondary' speakers, that is, your laptop speakers. Hope this helps!
Posted on Oct 10, 2009
grantg1983
  • 218 Answers
SOURCE: BOSE Companion 5 speakers connected to an Apple but no sound.
if you have a bose disk then you will need to run the install disk firsthope this helps if it does please rate this answer
Posted on May 15, 2010
bronk50
  • 27725 Answers
SOURCE: i connected a pair of
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Apr 17, 2011
KHANtheGR8
  • 277 Answers
SOURCE: pairing code for dell wireless 370 bluetooth mini-card
Normally when pairing with any device, any pairing code can be applied (4 digits),and then when asked on the other system, the one applied on the first system, will be required to put in. In most of the cases, it is pre defined as 0000
Posted on Jul 06, 2012
How to Connect the Bose Soundlink Mini to my Smartphone or Tablet?
  • Put the Soundlink Mini on charge. Then go to your Bluetooth device.
  • Go to the Bluetooth app. Turn on the Bose Soundlink Mini.
  • Press the Bluetooth button on the speaker. This makes it discoverable.
  • Watch the lights on the Soundlink Mini. ...
  • Press the 'Bose mini sou' button. ...
  • Listen to your music
  • Oct 18, 2016 | Cell Phones
    My bose bluetooth mobile won't link to my apple I pad,when I try to link them ,my I pad tell me that the sound system is not on
    Switch your Bose Speaker off.
    Open iPad - Settings - Bluetooth - Switch Bluetooth Off
    Switch iPad Bluetooth On and quickly switch Bose Speaker On.
    They should talk to each other as they find each other and fall in love :>)
    Bose Bluetooth speakers from I-pod are listed in the link below with manuals.
    On my Bowers and Wilkins T7 Bluetooth speaker you have to press the Bluetooth button on the SPEAKER the first time you connect it. After it is paired, it finds itself as soon as the speaker is turned on. I can highly recommend the B&W T7.
    BLUETOOTH Speakers Bose
    Jan 02, 2016 | Apple Bose SoundDock Series II Digital...
    How do I know if my bose mini soundlink bluetooth speaker needs a battery?
    [PDF]Owner's guide - Bose
    worldwide.bose.com/.../soundlink_mini/.../owg_en_sou...
    Bose CorporationMini Bluetooth® Speaker. Owner's ... to charge and discharge the battery pack several times to obtain ..... the Bose® SoundLink® Mini speaker battery lasts up.
    Sep 25, 2015 | Bose® CORPORATION Bose - SoundLink Mini...
    Can this be Bluetooth connected to my Bose mini speaker?
    With what device you want to connect your Bose speaker? Anyway, if it has bloetooth, probalby it should connect.
    May 11, 2015 | Bose Audio Players & Recorders
    Bose Soundlink Mini paired to Win 7 PC but will not play audio
    For pairing your bluetooth Bose speaker to your computer you might need to update the Bose speaker software
    I have included the link to download the actual software, and the updates available. According to the page for the download, you will need to have the speaker connected to the computer with a micro USB cord.
    SoundLink Wireless Mobile speaker update
    Aug 24, 2014 | Bose Corp Bose SoundLink Mini
    Bose soundlink mini paired to PC ( Win7) but wont play audio
    I have included the link to download the actual software, and the updates available. According to the page for the download, you will need to have the speaker connected to the computer with a micro USB cord. SoundLink Wireless Mobile speaker update
    How stop the Bluetooth indicator always flashing on my Soundlink Mini?
    Blinking blue light - Discoverable and ready to pair or reconnect with a device. See manual here: Bose SoundLink Mini Bluetooth Speaker Owner guide
    Jun 16, 2014 | Bose Corp Bose SoundLink Mini
    My iPhone don't work with my Bluetooth speaker system
    Paired is not connected. Connecting is the next step after pairing. Then make sure that the ilive speaker is set as the dudio output device.
    Dec 22, 2013 | iLive Bluetooth Speaker System
    Blue tooth speaker wont turn back on.
    Unable to connect to a device?
    Before attempting any of the following steps, make sure that you are running the latest software version on your SoundLink Wireless Mobile speaker. Click here to visit the software update center and update your speaker. If you are still having difficulty connecting to a device after updating the software, continue to the troubleshooting steps.
    Unable to connect with a previously paired device?
    Please try the following to resolve this issue:
    Perform a product resetTo perform a SoundLink speaker reset, following these steps:
    1. On the speaker, press and hold Mute for 10 seconds, the LEDs will flash briefly
    2. Press Power to turn the SoundLink speaker back on
    Clear the pairing list on both the SoundLink Wireless Mobile speaker and the source
    1. On the SoundLink speaker, press and hold the Bluetooth button for approximately 10 seconds until you hear a tone. The SoundLink speaker clears all Bluetooth devices from its memory and becomes discoverable
    2. Clear the list on your Bluetooth device. For more information, please refer to the manufacturer of the device
    3. Perform a product reset. On the speaker, press and hold Mute for 10 seconds, the LEDs will flash briefly. Press Power to turn the SoundLink speaker back on
    4. Try pairing the device again by following these steps:
      1. With the Bluetooth device and the SoundLink speaker both turned on, press and hold the Bluetooth button on the speaker for three seconds to make the speaker discoverable. The Bluetooth indicator will slowly fade on and off approximately once every second to show the speaker is in discoverable mode
      2. Set your Bluetooth device to "Discoverable." This will allow your device to discover the SoundLink speaker
      3. On your device, locate the Bluetooth device list. Select "Bose SoundLink" from the list
      4. If your device asks for a passkey, enter digits 0000 and press OK. Some devices also ask you to accept the connection. Your Bluetooth device indicates when pairing is complete. The SoundLink speaker indicates pairing is complete when the Bluetooth indicator stops fading on and off and remains on
    Be sure the SoundLink speaker is within 30 feet of the Bluetooth deviceThe system is designed to operate at a range of 30 feet. However, performance can be diminished by obstacles such as walls or metal, and may also be affected by other Bluetooth devices. Try moving the SoundLink speaker closer to the Bluetooth device.
    Be sure the source's Bluetooth function is OnMany Bluetooth enabled devices have an option where the Bluetooth feature can be turned On or Off. This option may be set to Off to save the battery life of the device. Be sure this option is set to On. If the Bose product is paired to the Bluetooth enabled device, it should automatically reconnect when its Bluetooth function is turned on. If the Bose product doesn't automatically reconnect, manually select the Bose product within the Bluetooth list on the device.
    Manually connect the SoundLink speaker in the device listSome devices will pair to a device but not automatically connect. Go to the pairing list of the device and check if this is the case. If it is, try connecting to the SoundLink speaker.
    Oct 20, 2013 | Just Wireless Bluetooth Headset Wireless...
    23 people viewed this question
    Top Bose Audio Players & Recorders Experts
    Steve Allison
    Steve Allison
    Ekse
    Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
