J
Jacqques Lorrain Posted on Sep 17, 2019
Just bought a Olympus DS 9500. Set it up. When i record it will not send note to my PC. Jacques
5 Related Answers
JULIANFIX
ALBERT GARCIA
  • 975 Answers
  • Posted on Apr 27, 2008
SOURCE: Where can I obtain the software for the Olympus DS 330 voice recorder that is required to be able to download files to my PC
go to this link:
http://www.olympus-europa.com/consumer/2590_3505.htm?prodID=P_053011 , hope this helpful
Anonymous
  • Posted on Dec 29, 2008
SOURCE: Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Anonymous
  • 919 Answers
  • Posted on Mar 16, 2009
SOURCE: need to download to PC the Olympus DS-2 software
http://www.olympusamerica.com/files/DSSPlayer.zip
After unzipping the file, click on the SETUP.EXE file to begin installation.
License key: 8360 0121 0002 6901 5480
Download update 7.1: http://olympusamerica.com/files/DSSV7UP2EN.zip
Anonymous
  • 919 Answers
  • Posted on Jul 28, 2009
SOURCE: my olympus voice recorder dosen't work on PC?
Digital Wave Player (2.0):
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
Download update: http://olympusamerica.com/files/DWPUP2EN.zip
Download update 2.1.3: http://olympusamerica.com/files/DWPUP4EN.zip
Do not have recorder connected until all software installed and then reboot computer. Once computer rebooted then connect the recorder.
iyuhbewrfv
Roger
  • Posted on Nov 17, 2014
SOURCE: OLYMPUS DS-330 Drivers
Hi Aklas.
Olympus DS-330 voice recorder drivers (xp/vista/win7/win8/mac) can be found at driverupdate us
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Software for old DS 330 Voice recorder
The DS-330 Voice Recorder was a portable digital voice recorder produced by Olympus. If you are looking for software to use with this device, you may be able to find it on the Olympus website or by contacting Olympus customer support. However, it's worth noting that this device was released in the early 2000s and may not be compatible with modern computers or operating systems. It's also possible that Olympus no longer provides support or software updates for this device. If you are having trouble using the DS-330 with your computer, you may need to use a different digital voice recorder or consider using a different type of device for recording audio.
2answers
What is the best digital recorder for a lawyer -- the Olympus DS-5000, Phlips LFH-9600 or Philips LFH-9500? Are there any other good alternatives?
The Phillips LFH-9600 is a popular unit in the professional category.
Everyone will have their preferences....also check on Warranty and service for your geographical area, as these are issues to consider before purchase.
I bought an Olympus DS 40 from ebay - ie wothout
open the battery compartment there is a very small white sticker that has your serial number hard to read but it is there enjoy!
2answers
How do you retrieve corrupted files on a DS-3300
If the files are corrupt then you could only retrieve corrupted files which would be useless.
Sorry.
Can't access the software for DS50 digidtal recorder
you will need to call tech support at olympus... they will work with you in cleaning up your registry and getting the software to work properly
The slide switch on my Olympus DS-4000 digital dictation recorder is too sensitive, and often goes to the "Record" position when it should be "Off." Any suggestions in how to correct...
The slide switch on your Olympus DS-4000 probably needs to be replaced. You can ship it to PCDictate.com to have your Olympus DS-4000 repaired. The repair will most likely run around $100,
However, my suggestion is that you upgrade to the Olympus DS-5000 digital voice recorder, the replacement for the DS-4000. It is a substantial upgrade and you will not regret it.
If you want to consider another brand, Philips has some great digital voice recorders. My favorite models are the Philips LFH-9600 and Philips LFH-9500 professional digital voice recorder.
The best place to purchase professional digital voice recorders is PCDictate.com. Your recorder will be shipped the same day your order and shipping is free.
2answers
Can't use my voice recorder anymore
try to connect the recorder to the PC and with the Olympus DSS Player Version 7 change the folders name to default
Top Olympus Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Ngoro
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
