Question about Radio Communications
Do the headset got a reset button - Radio Communications
    Sergeant:
  • 204 Answers
Most headsets do not have a reset since there is nothing to reset. If you need to pair it again with a phone, go into the settings of the phone, find the bluetooth device list and tell the phone to forget the headset. then do the pairing again, after fully charging the headset.
Posted on Sep 24, 2019
SOURCE:
I'm trying to recharge my headset but the green light remains on (I clicked on the botton on the headset piece but it won't turn off). When I try to turn it off, it beeps at me
try doing a system reset press the call control button and the volume mute button at the same time for 5 seconds. when the talk indicator light blinks release both buttons. press the call control button again and the talk indicator light will blink again briefly headset is back to normal then unplug the charger from the charging jack for 5 seconds and plug back in headset is reset. if that doesnt work then replace the battery in headset.
May 05, 2011 | Plantronics CS55 Wireless Headset
Can't get it to show up on my phone
How to perform a system reset
Start with the headset off (no light). Press and hold the on/off button and without letting go plug in the AC charger (you will see steady light on the headset). Let go of the on/off button as soon as you see the steady light. Unplug the AC charger from the headset. Test the headset to see if the reset was successful.
If this does not resolve your issue you may have to replace the headset through Plantronics Service Center.
Good luck from Headsets Direct!
Apr 20, 2011 | Plantronics Backbeat 903 Bluetooth...
How to reset a password
Try 0000, that should be a default code.
If not then It is possible to reset and test the headset. Make sure that the
headset is powered off. Press and hold the answer/end button
and the on/off button at the same time for 10 seconds.
The headset will automatically turn off after approx. 10 seconds.
The next time you power on, the headset will go into pairing
mode as the first time you powered your new BT2070 on
Hope this helps.
Thanks
Apr 16, 2011 | Jabra Bluetooth Headset - BT2070
Savi Office WO100 won't charge. The green light on the base is blinking but my computer says there is 0% percent charge.
There are two possible solutions to this issue:
1. The headset needs to be reset.
2. The headset is defective and should be replaced.
To reset the headset, use a straightened paperclip to push the reset button on the inside of the headset, below the earhook. See the pic:
You may need to hold the reset button for a few seconds. Then replace the headset into the cradle. You should see normal behavior again.
If this doesn't work. you will need to replace the headset.
Apr 07, 2011 | Plantronics Savi Office Wireless Cordless...
My Mute button won't work any longer. Is this fixable?
Try to preform a system reset and see if that solves your issue. Start with the headset off (no light). Press and hold the on/off button and without letting go plug in the AC charger (you will see steady light on the headset). Let go of the on/off button as soon as you see the steady light. Unplug the AC charger from the headset. Test the headset to see if the reset was successful.
Jan 14, 2011 | Plantronics Backbeat 903 Bluetooth...
Red light constantly flashing. I can't make it stop to pair it..
Dec 12, 2010 | Plantronics Backbeat 903 Bluetooth...
All of a sudden my CS 55 with plantronics stopped working. It shows that its on but the headpiece isnt charing and also doesnt work. Any ideas why?
If the Plantronics CS55 wireless headset shows that it is on, you have to make sure of the following things.
a. the green LED on the base turns on when you turn the call switch on from the headset.
b. the small green LED on the side of the headset is blinking.
c. the telephone headset is lifted from the cradle.
d. if the headset is not charging and the Amber light on the base does not blink when you place wireless headset on it; trying placing the headset more firmly.
e. If the headset is not charging and the Amber light on the base does not blink even after placing the wireless headset firmly on the charging cradle, you may need to change the battery.
Alternately you can try resetting the Plantronics CS55 wireless headset.
Reset Plantronics CS50, CS60 or CS55 Wireless Headset
If you have problems with the sound or connection of your Plantronics CS50, CS60 or CS55 wireless phone headset, you may want to try to hard reset it using the following steps:
Note: Ensure the IntelliStand switch (on the right side of the charging base) is in the - position and NOT the = position.
1. Press both the call control button and the listening volume/mute button for 5 seconds. When the indicator light blinks release both buttons.
2. Press the call control button again. The talk indicator light will again blink to indicate the headset is back to normal.
3. Disconnect the AC charger from the AC charging jack for 5 seconds.
4. Reconnect the AC charger.
Now give the Plantronics headset a try.
Jan 10, 2009 | Plantronics CS55/HL10 Wireless Office...
Static
SYSTEM RESET To recover from some fault conditions (refer to the Troubleshooting Section) you may need to perform a system reset. To perform the system reset follow this procedure: 1. Press both the talk button (14) and the mute control (15) button on the headset for 5 seconds. 2. When the talk indicator light (17) on the headset blinks, release both buttons. 3. Press the talk button again. 4. Next reset the base unit by disconnecting the AC power adapter (24) from the AC power adapter jack (7) for 5 seconds, then reconnect. The system reset operation is complete.
Jun 19, 2008 | Plantronics CS50 Wireless Office Headset...
How can i reset my nextel i 930
keep the nemu button pressed while phone is off then press power button it will ask you "press ok to format" and voila done new phone and password reset.
Apr 01, 2008 | Nextel i930/i920/i870 Stereo Headset [OEM]...
How do i reset it?
You may need to reset your Bluetooth devices. Please follow the steps below:
1. Delete BT150 from cell your phone (if listed).
2. Turn your cell phone off completely, and remove battery for 10 seconds. Please consult your phone provider prior to removing battery.
3. Connect the BT150 headset to the charger for 10 seconds, then unplug.
4. Place the battery back into your phone and power your phone on.
5. Remove the headset from the AC cord.
6. Turn off the headset by pressing the answer/end button until the light flashes rapidly, then release.
7. Turn the headset on by pressing the answer/end button until you receive a flashing blue light.
8. Press and hold the answer/end button and the volume plus (+) button until you receive solid blue light. This may take up to 10 seconds.
9. Go into the Bluetooth menu on your cell phone and follow the cell phone’s instruction guide for pairing a Bluetooth headset. This generally involves going into a “devices” or “hands free” menu and adding a new device. Your phone may ask if you want to pair with the headset, accept by pressing “yes” or “OK” and confirm with the passkey or PIN 0000 (4 zeros).
Oct 09, 2007 | Jabra BT150 Wireless Headset
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
