Hello. I have a Haier mini fridge. When I first plug the fridge in it starts up fine, but after a few hours of use it begins making clicking noises about every 5 minutes and the back of it feels VERY hot. The inside of the fridge and small freezer compartment also turn very warm. What can I do to fix this?
SOURCE: FRIGE AND FREEZER ARE WARM NOT WORKING
Make sure you hold the door switch closed too check if the evaporator fan is working also check if the evaporator coils are froeen up..
SOURCE: Fridge not cooling compressor works intermitently
If the compressor starts and runs for a few seconds it could be the relay. Or it could be the compressor itself has failed. When a compressor starts and runs for a short period it is possible that the relay contacts are arced together which would have both the start and run winding in the motor engaged at the same time for more than 3 seconds. This would result in the compressor tripping out on the thermal overload. It depends on what type of relay your compressor has. If it is a thermal relay, unplugging the refrigerator for about 15 minutes would allow the relay to cool off and reset.
SOURCE: Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
SOURCE: panel between fridge and freezer very hot and no sound at all
Dont know about the noise prob. but I can help with the over heating cabinet. Your condensing coil is dirty and needs cleaned. it is located under your refrigerator or behind the back panel. You should use a brush and vac. it out. Air must travel through the tubing freely in order to cool properly. It should be easy to find following the tubes coming out of your compressor.
SOURCE: fridge warm freezer cold
you may have a defrost problem check to see if you have frost up in the freezer
