Question about Samsung Cameras
My Sonata is paired with my new Samsung A50 but it will not download my contacts to the car.
Is 4gb SDHC card compatible with Samsung A50 camera,will not format,says card error
The A50 works with MMC and SD cards, 2GB or smaller. It does not work with higher-capacity SDHC cards.
Oct 20, 2012 | Samsung Digimax A50 Digital Camera
Have mislaid my instruction manual for the Samsung Digimax A50 camera. Can I download one onto my computer please?
Do you perhaps mean the L50? If so, the manuals can be found at the following link:
http://www.samsung.com/us/support/downloads/DIGIMAX%20L50
May 05, 2011 | Samsung Cameras
I cant find my manual for my samsung digimax a50 and i need to turn on the self timer but im not sure how to
Go online to google.com and enter digimax a50 manual and you should be able to get the info online
Nov 29, 2010 | Cameras
Card error - samsung a50 (card 4GB SDHC)
the card reading error appears when the card is locked by the side button ..and you try to make an operation forbidden by this locking action ...another thing may be a reading issue based on the card reader driver malfunction ...so reinstalling the card reader will be a point to start ..after that be sure that the card is not physically locked by the side slide button ..and the last thing be sure the files are not protected...another issue that may cause the error is the contacts of the card itself ...insert it proper and be sure they are not oxidized ...
If you do not have important files on it ..a formatting will be a good thing to do ...
Aug 02, 2010 | Samsung Digimax A50 Digital Camera
My digimax a50 camera keeps saying card locked
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jun 16, 2010 | Samsung Digimax A50 Digital Camera
Oil fill cap on 06 sonata just turns will not unscrew out
I'm guessing the cap cover has separated from the cap base. If you gently pry at the cover, It should just pop off and then you can take a pair of pliers and twist and pull the bottom half off. You'll probably need to buy a new oil cap
Sep 25, 2009 | 2006 Hyundai Sonata
I'm trying to downloade my address book or contact list from my cell phone (Samsung SGH-a437) into my SYNC Navigation system in my new Ford 2009 F250 HD? I can receive phone calls but have not been able to...
un pair the phone then re pair the phone if it does not automatically ask if you want to download the phonebook then you have to push the numbers to the phone manually by going to the phone book folder where is says to add contacts and it will more than likely let you push them with your phone by going to the phone number in your phone and sending to sync with the send via bluetooth option...
Jun 15, 2009 | Samsung SGH-a437 Cellular Phone
Annoying menu chimes
Hi - You can download the manual from the link underlined in blue below:
Digimax A50
The shutter sound is set on page 93:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 31, 2008 | Samsung Digimax A50 Digital Camera
Cameras Logo
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
