depends on the iPod model you have:
iOS 6 runs only on iPod Touch 4. Gen. !
For the iPod Touch before iOS 5 to update is only possible with connecting the device to iTunes on a computer. Plug it into your computer and open up itunes under devices click on your ipad and then click on check for update.
<p>When you download games on your iPod touch, they are
applications on your mobile device. When you connect your iPod Touch to a
computer with iTunes installed, the iPod synchronizes and shares data with the
computer. Once synchronized, you can back up your games and other applications
in the iTunes case something would happen to the data on your iPod Touch. After
the first sync, every time you touch your iPod to your computer, iTunes
automatically detects new applications and backs them up. <br />
<p><br />
<p>1. Launch the iTunes software on your computer. <br />
<p><br />
<p>2. Connect your iPod Touch into a USB port on your computer
using the cable supplied with the unit. <br />
<p><br />
<p>3. Let the iPod Touch to sync with the iTunes software. The
"Sync in Progress" message will appear on your iPod during the
process. <br />
<p><br />
<p>4. Click the name of your iPod Touch to the left of the
iTunes window. On the device displayed in the right pane. <br />
<p><br />
<p>5. Click on "Applications" tab on the top menu. <br />
<p><br />
<p>6. Click the box next to "Sync Apps", and attach
the sync as the pop-up window will appear. <br />
<p><br />
<p>7. Click the "Sync" button in the lower right
corner. This makes a backup of your iPod Touch games on the computer. <br />
<p>Apple iPod line was originally designed as a portable music
player, but the newer models are portable multimedia devices capable of many
things: playing music and videos and view photos. In addition, some models such
as the iPod Touch even install and run applications and games. You can download
games and applications from the iTunes store on your computer and copy them to
your iPod Touch. <br />
<p><br />
<p>1. Connect the larger end of the iPod to the USB port on the
bottom of your iPod Touch. <br />
<p><br />
<p>2. Connect the other end of the cable to a USB port on your
computer. The iTunes software is automatically started when your computer
recognizes your iPod Touch. <br />
<p><br />
<p>3. Click on your iPod Touch in the "Devices"
section on the left side of the iTunes window. <br />
<p><br />
<p>4. Click on "Applications" tab at the top center
<p><br />
<p>5. Scroll through the applications and check the box to the
left of each game you want to copy to your iPod Touch. <br />
<p><br />
<p>6. Click "Apply" and then click the
"Sync" to select your iPod to copy games to your iPod Touch. <br />
<p>Vivid is a set of custom themes available for your iPod
Touch in Cydia App Store. Vivid Themes change the look and feel of your iPod
Touch device with custom backgrounds, menus and icons. Cydia is an alternative
to the Application Store, found on jailbroken iPod touch devices. Download and
install themes Vivid directly to your device from the Cydia app store. <br />
<p><br />
<p>1. Touch the "Cydia" icon on your jailbroken iPod
Touch. <br />
<p><br />
<p>2. Select "Search" icon and type in
"Vivid" in the search bar Cydia. Select "Search". <br />
<p><br />
<p>3. Select "Vivid" to the list of available
applications. <br />
<p><br />
<p>4. Tap the "Install" button. <br />
<p><br />
<p>5. Tap the "Confirm" button to download and
install the application on your device Vivid iPod Touch. <br />
<p><br />
<p>6. Select "Reboot Device" button. <br />
"1. Connect the iPod Touch 2. Press and hold sleep+home until the device reboots. 3. Keep holding until that "please connect me to iTunes"-screen appears 4. iTunes says something about having detected a touch in recovery mode. Allow it to do its thing.
If you get the -18 error, proceed:
5. Disconnect the iPod Touch 6. Close iTunes 7. Reconnect the iPod Touch 8. iTunes launches and shows message as in step 4, but this time, the recovery will work."
Hope this helps!
