Hi Christina, as you say, it is very certain that the back lighting is wrong
Indicate the model of your LG TV you are commenting on, in order to find the best possible solution on the type of LED strips it has
I wait your answer
Greetings Franco Dosil
Hola Christina, por lo que comentas, es muy seguro que se encuentre mal la iluminaci?n trasera
Indica modelo de tu TV LG del que estas comentando, para poder encontrar la mejor soluci?n posible sobre el tipo de tiras LEDs que lleva
Espero tu respuesta
Saludos Franco Dosil
SOURCE: LG RZ 37LZ55 37 in HDTV LCD Screen Dead
This is likely due to a failed power supply. Replacing the power supply board should solve the problem.
http://www.reviewcentre.com/reviews110919.html
Cr1spy
SOURCE: lg lcd tv screen goes
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
SOURCE: 42" LG Plasma tv, no picture - black screen, but have sound.
Most a likely a problem with your Y-Sustain board which will then not drive the screen giving a black picture. The fuse on the board may be open circuit & need replaced but most likely you will need to have the sustain board replaced.
SOURCE: My LG TV 60PY2DR has sound but the screen is black, what's wrong?
i could be some caps on the power board,but id take it to a shop as these are pretty high voltage and id hate to see you get hurt
SOURCE: LG tv sound quit - will it work if I add external speaker system
Maybe!! It depends on where the audio sys failed. If it failed at the output drive, then you can take the audio off at the audio output jack and input it to your stereo system where there is an audio input. You'll need a cable with RCA jacks on it for this.
If your system is muted for some reason, this may not work.
Hi Christina White Mckereghan,
Can you Put a flashlight on the screen and see if you can see the screen as this would suggest a fault with the backlight or inverter that drives the back light.
