SOURCE: Bluetooth keeps aking for a pairing code. each 4
Did you try just pressing enter (no code)? If not, try "0000" I found something here: http://fordfcsd.wunderman.be/UK/Audio%20-%20Multimedia%20-%20Navigation/Bluetooth%20%26%20Voice%20control/bluetooth%20%26%20voice%20control%20%28cg3504en%29%2001-2006.pdf which indicates "0000" is the code, but enter should do it
Testimonial: "worked with an old module i have, but radio is stuck on mute wid dis one. when i insert my newer module,it dos not pair with the phones but BT show up"
SOURCE: My Jwin Jb-Th710 does not
I assume you can find the button on the bluetooth headset which you can press and holds it for about few seconds until it turns on (usually there will be blue and red lights light up, NOTE: whenever both blue and red lights up, means it is in discovery mode!!! This is the right mode to pair with phone.)
And to setup the iphone. PLEASE follow up the instruction HERE, click "Settings" ---> General ---->
Bluetooth ----> Turn On Bluetooth -----> Select the Device Name (FIND the right name of your product and click!) ----> Ask for a passcode to pair (In general, it's 0000.)
Then, after you done that, you should be able to see only red light is popping on your headset which means your pair process is complete.
LET me know if you have any further questions.
good luck!!
SOURCE: em227 wont pair with samsung
make sure that the code you enter in to the phone as the pairing code is correct. most of them are 0000 or 00000, some of the samsungs are 1234.
this code must be entered in correctly to pair the device. If you are using an iphone, there are some issues with it people report.
Switch off completey. Boot up in safemode by pressing vol+ button. After all is complete, go to bluetooth settings and run. While it search, tap the small arrow which brings u to Forget this network, tap again and forget it. Then, a fresh restart and you will see the bluetooth up and working. So far 78% is working...thnk u, like pleasa
