Question about Stoves Ovens
Moved into house with a Stoves double gas range with electric oven ,l can't work out the clock and how to set the timer to cook.model number 0505644148 please help
SOURCE:
  • 487 Answers
SOURCE: timer clock on bosch double oven
Please follow this link and download the instructions.
Manual
Please rate me as FIXYA
Posted on Apr 29, 2008
SOURCE: Setting Clock and Timer
Worked it out for myself - no solution needed now thank you.
Posted on Jun 22, 2008
  • 32 Answers
SOURCE: trying to set oven timer
Hi, switch off the mains for the cooker, wait for about 15 seconds then press the 2 buttons on the left and hold them, and then press the - or + button to set the time.
Cheers
Posted on Feb 19, 2009
SOURCE: Stoves Gas Oven
i am having the same problem but i have been told it is the cooler fan so i have ordered a new one,the fan unit requires running as it is linked to safety sensors the equal air preasure and if not equiled by the fan moter it cuts everything off and in my case it trips the mains power but may not in your case
Posted on Oct 05, 2009
  • 250 Answers
SOURCE: i have a Stoves double
The clock controls the ovens. In other words, directly you set any time on the clock, a contact operates within it to provide power to the ovens. (Normally the grill remains operational). You may need a new clock/timer. Before you do so, try switching the power off at the main isolating switch and leaving it off for a few mins, then switching it back on, to try to get the clock to operate. You may need to do this a few times.
Normally Stoves stick a label identifying the model on the left hand edge of the lower oven. You see this when you lower the main oven door. it will probably start with a 05 and be 9 digits long. With this number you can identify the oven and obtain parts.
Posted on Nov 18, 2010
I have a stoves 720ef oven and cannot get rid of the auto
The handbook says:-
To cancel the automatic setting and return the oven to manual operation, press the cook time and ready time buttons simultaneously. These are the second and third buttons from the left. If you have done that and it is not working, try turning the complete oven off for awhile - say 30 mins and turning back on. If this still doesn't work then it may be that the timer/clock has gone faulty.
Nov 10, 2011 | Stoves 720EF Electric Double Oven
Hello, can you help, my daughter has just moved into flat which has a stoves 720 EF double oven. For some reason we cannot get it off the Auto mode, We have tried every possible combination of the five...
It could be that the clock is on the way out, or the buttons that control the clock have dirty contacts. espares can get you a new clock/timer. What you can do is with the oven switched off, rapidly press all the clock buttons one at a time to try and remove the dirt. Switch the oven back on and see what happens. If you need a handbook, post an email address and I will send you a pdf copy.
I have answered other posts in this section on how to use the timer, so check there if you don't have the information.
Aug 21, 2011 | Stoves 720EF Electric Double Oven
Just moved address, new house has a Stoves 720 EF built in oven.Model 059040437. I can't work out how to turn on the grill or set the timer, don't understand what any of the symbols on the front left next...
I don't know if this will help. For the 720ef , this is what you need to do.
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
TO SET THE TIME OF DAY
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
TO SELECT AN ALARM TONE.
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
SETTING THE MINUTE MINDER.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remaining time.
If you want all the information, then it is best if you supply a vaild email address and this will give you access to my BT Digital Vault, where you can have a complete copy of the handbook that I have scanned in.
Jan 10, 2011 | Stoves 720EF Electric Double Oven
I have a Stoves double oven and after a power cut the clock has stopped working and the main oven is not working either. the clock is completely off. the small top oven is still working though. what can...
Nov 07, 2010 | Stoves 720EF Electric Double Oven
Moved to house with a Simpson Neptune oven (analogue clock)
Try this. For the 720ef , this is what you need to do.
Jun 17, 2010 | Stoves 720EF Electric Double Oven
A (automatic cooking)remains in the digital reader which means that the electric oven/grill and fan oven won't work. It will not clear from the box.
What happens when you turn the power off to the whole oven, leave it off for a few mins and then reapply? If the automatic is still set it could be the clock is faulty.
Have you tried resetting the clock as per the handbook?
Dec 01, 2009 | Stoves 720EF Electric Double Oven
Have lost the user manual and need to reset the clock and timer and would appreciate some advice on how to do this. The Stove is a heritage 720EM
Like most ovens you press the 2nd and 3rd buttons simultaneously (cook duration & finish time). While doing so, use + or - to set the time.
Aug 14, 2009 | Stoves Premier 720EMa Electric Double Oven
How do I set the clock time on Stoves Cooker efa700h. I would assume the clock is the same on most stoves models
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remianing time.
Aug 02, 2009 | Stoves 720EF Electric Double Oven
Manual for Stoves EL716 oven
I have a Stoves Newhome EL716 double electric oven and last night, it just lost all power and stopped working - no grill, oven, lights, clock or anything. Can anyone tell me what this could be please? Thank you.
Feb 22, 2009 | Stoves 720EF Electric Double Oven
Ovens Logo
22 people viewed this question
Top Stoves Ovens Experts
John Tripp
John Tripp
Marvin
Marvin
Anthony Ward
Anthony Ward
Are you a Stoves Oven Expert? Answer questions, earn points and help others
