Question about Kenmore Ovens
My Kenmore oven shows error code F-1. Model # 790.47853406.
We had a power outage and after resetting clock time it won't respond to "Bake". Instead the error code shows. What should I do?
SOURCE:
  • 159 Answers
SOURCE: Dacor Oven Won;t Heat
power surges can short out the electonics in appliances. If you can locate where the tech sheet is and I would say its behind the control panel on top, look at the wiring diagram and see if there are any replaceable fuse's. Or a resetable fuse for the heating element. If not check to see if power is getting to the main control bord. If there is power there you may need to replace the control.
Posted on Jul 20, 2007
SOURCE: kenmore oven touch panel error codes f1 f3 f5 f7, oven failure
I had the same problem. It occurred when it was in a cleaning cycling. I fot the F3 Fasult and also the door remained locked. I let it cool down overnight and killed the power at the circuit breaker. I turned the power on and got a F3 alarm and the door remained locked. I took our the screws holding the control panel and pull it out far enough to give me access to the locking mechanisim. I took out the screw holding the locking latch to the motor. With the latch loose, iwas able to get move it out of the door lock. With the door now open I was able to get to the temperature sensor with was held with two sheet mmetal screws. The screw were impossible to get out, so I ground off the heads with a Dremel tool. I couldn't get the sensor wires out. So I pulled the unit out to get at the back sde. I cut the old sensor wires and was able to get in the hole to remove the screws with a pair of needle nose pliers. I installed a new sensor and with wire nuts attached the sensor wires to the computer wires. Make sure that you work the insulation in the hole to plug it back up. Put the oven back in and installed the sensor in the oven with two small sheet metal screws. . refasten the locking latch to the locking latch motor. turn on the power and everything was fine. I ohmmed out the old sensor and it was 180 ohms at room temperature. The replacement checked out at a 1000 ohms in accordance with the schematic for the control. By the way, the schematic was neatly folded on the control panel when I removed it I used a Whirlpool sensor Part No. 12001656 which was half the price of a Kenmore sensor. +
Posted on Oct 24, 2008
  • 5 Answers
SOURCE: stove-top works, oven showing all 888888 across the screen
You're stove must be perfectly fine, but the thing displaying all those options may have a problem. Try to get this fixed as soon as possible.
Posted on Feb 15, 2009
  • 530 Answers
SOURCE: 665.95802000 f1 - E 1 error code
take the consol off you will find the tech sheet with all the codes. make sure you turn your power off first.
Posted on Dec 23, 2009
SOURCE: I have a Kenmore Ultra Bake Stove, we had a power
PF is usually power failure.
If "PF" appears at any other time, a power failure occurred. To remove "PF"and to reset the clock, press STOP/CLEAR.
Unplug the unit for half an hour or so to see if it will reset.
If not try to get into the diagnostics so you can see if there is a stored
error code
Posted on Feb 15, 2010
Kenmore electric range/ovens
Most likely the clock / control or a thermal fuse if your model has one.
Oct 09, 2017 | Kenmore Ovens
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
My Kenmore 911-4298814 oven won't hold broil or bake temp setting. The oven powers on with no error. When I press the "Bake" and dial up a temperature to (say) 350 degrees, the LCD displays...
just had similar problem with frigidaire, temp display would go blank, not even show clock, i took off back of stove, the circuit board would wiggle. when i pushed in on the circuit board it worked correctly.
Oct 30, 2011 | Ovens
I cannot use the oven
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 29, 2010 | Kenmore 47712 / 47714 / 47719 Electric...
My oven will not bake anymore b/c it is showing e3 f1 problem. How can I fix this ?
Jun 25, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I have a Kenmore Ultra Bake Stove, we had a power outage and neither the oven nor burners works. The code on top reads PF 5Ab. What can i do to reset the stove?
error code
Feb 15, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Dec 23, 2009 | Kenmore Ovens
Stove-top works, oven showing all 888888 across the screen
Jan 31, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
Top Kenmore Ovens Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
