Question about Olympus Cameras
OLYMPUS RS31H not connecting to USB port. No indication on any computer that it is recognized when I try on multiple computers. Do I just njeed a new USB cable or a whole new foot switch.
6ya staff
SOURCE:
Anonymous
SOURCE: Computer doesn't recognize unit when connected
Hi All,
I had the same problem and was going crazy trying to figure this out, but I found that I had installed the GPX mw3816 on my bottom USB port and was trying to plug it into the port above it, because I had plugged another unit into the bottom port, but I switched the ports and it immediately installed. This is another reason, I am thinking of dumping windows and moving to a MAC. Peace!
Posted on Jan 04, 2008
Dave117
Dave117
  • 134 Answers
SOURCE: Maxtor one touch 4 mini-
Quite strange.. I would suggest that maybe one of the usb ports is faulty.. Or ofcourse, one of the cables.. Or the usb port has been mis-wired inside the pc. That has been done before. Anyway, do you have access to 2 usb drives.. I mean micro/thumb drives? I'd test each port by itself first, to see if they operate correctly, then if they do, use the two usb drives in the two usb ports at the same time, to test read & write.. I guess there are other things you could try, like going to control panel, system, hardware, device manager & checking on the status of the usb ports. That may tell you something worthwhile. Whatever you do, test each port with the one single cable. Yer, this is a strange fault. Let me know how you go. Rgds,
Posted on May 11, 2008
gymowner
George Bill
  • 679 Answers
SOURCE: gigaware usb to serial cable problem with vista driver download
can you see the new device in the device manager, you may need to install it, did you get disks, to install it if so go to add new hardware in the control panel and you may need to manually install the device. It will at some time ask for a disk, so have it ready, peace, Gym
Posted on Dec 21, 2008
Anonymous
  • 73 Answers
SOURCE: Computer won't recognize Olympus FE-340 when USB is plugged in
some computers just seem to do that, it happened on me before. if you have a card reader just put the card into that and read the pictures from that.or just try a differant port if you havent allready
Posted on Mar 24, 2009
Anonymous
  • 919 Answers
SOURCE: need driver for vista for olympus stylus 710
To learn about the new and free version of Olympus Master 2 software go to:
For Windows:
http://downloads.olympus-europa.com/OM2/win/OM211Setup.exe
For MAC:
Olympus Master 2.11: http://downloads.olympus-europa.com/OM2/Mac/OM211EN.dmg
This software replaces all previous versions of Camedia Master 4.x and Olympus Master 1.x.
Posted on Jul 28, 2009
Programa no responde
If I understand your problem right, the installed Olympus program does not launch (start) when connecting the camera to the computer using the Olympus' USB cable.
1. For the program to start automatically, the camera must correctly being recognized by the computer. Check if this is the case! When connecting the camera to the computer, you should see information shown on the camera's display!
2. If not, try to connect the camera on another USB port, or better another computer to diagnose the problem.
3. If the camera is recognized, you can set an option in the program to autostart the program when connecting the camera to the computer.
4. If it does not help, reinstall the program.
May 27, 2011 | Olympus SP800UZ Digital Camera
I have plugged it in and it my computer will not recognize that the USB is even plugged in, but it does charge the camera.
Try all the different USB Ports on your computer, sometimes certain ports can 'glitch' and not recognize the device that you've plugged in. If you've tried plugging it in all the ports and your computer still hasn't recognized the camera, re-install the driver software for the Olympus SP800UZ.
If all else fails, you can also contact Olympus customer service, they're quite prompt and helpful.
May 17, 2011 | Olympus SP800UZ Digital Camera
I have a 500 GB Lacie mobile drive and when I connect it using a USB cord it won't be recognized on the computer, however when I connect it using either the 400 or 800 firewire it works. I am having the...
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
Aug 10, 2010 | Computers & Internet
When I connect the camera with a usb to my computer that has windows. Why isn't it recognized?
If software and drivers are installed correctly, and the coonection still fails, try another usb port on the computer. Ususally the ports on the back of the computer will work.
Jun 18, 2010 | Olympus Stylus 830 Digital Camera
Printer USB Cable un recognized DCP150C
You need to isolate the problem. You tried using multiple cables and reinstalled the printer driver several times, but you never mentioned that you tried connecting the printer into another computer. What if the problem is the USB port of the computer and not the printer cable?
Try connecting and installing the problem printer into different computer for testing purpose only. If it work, then the problem is the USB port of the computer. To fix this, try updating the USB driver of your computer.
If same problem occurs using another computer, then you need to contact the manufacturer of your printer. I've heard this problem before and I don't have an update if there's a fix with it.
Have a great day!
Oct 01, 2009 | Brother Office Equipment & Supplies
Mar 24, 2009 | Olympus FE-340 Digital Camera
Computer not recognizing Camera
Are you always using the same USB-port on your PC? If yes try to use another USB-port.
If the above solution will not work try to re-install the camera drivers.
Oct 25, 2008 | Olympus FE-100 Digital Camera
Olympus E510
Make sure the camera is on and STORAGE is selected on the camera screen when connected to the computer. You will need to have STORAGE highlighted and select OK on the camera as this starts the camera and computer to communicate. Once communication established the LCD screen of the camera goes dark and the computer should generate a removable disk drive. Check the System Tray (lower right corner beside the PC time) for Safely Remove Hardware. When you click on it, it should read "Safely Remove USB Mass Storage Device Drive ?:" If you dont see that, then check the Device Manager to see if the camera is recognized as USB Mass Storage Device. The camera uses the driver usbstor.
Aug 01, 2008 | Olympus Cameras
Need a driver for FE-190
need a driver or cd to download my pic on my computer olympus FE 190
Mar 30, 2008 | Olympus FE-190 Digital Camera
No usb port found
If you can't find such on your machine, then it's either disabled, the BIOS is out of date, the OS doesn't support your USB (Examples abound!) or other. I cut my time loss by adding an USB PCI card.
Sep 06, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Cameras Logo
29 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
