SOURCE: riding lawnmower starts but will not continue stay running?
its probably in your ingnition switch, grab the switch and turn it right the turn key I had the same problem and that fixed it. It also wasnt starting and it was the same problem the switch is lose.
SOURCE: mower wont start
The flywheel key has sheared and it needs to be replaced. Replacing the flywheel key is a fairly straightforward procedure. Otherwise, it will be necessary to take the mower to have someone replace the flywheel key.
Here are some steps to follow to replace the flywheel key on your own (instructions are for a toro 20016 model mower):
SOURCE: my cub cadet stops running 5-10 minuts
check the bowl for dirt or try putting in some stable
SOURCE: cub cadet dies 20 minutes after starting
Slacke off the fuel filler cap when it starts to die, if it picks up again the fuel tank breather is blocked.
SOURCE: cub cadet riding mower wont start... parking brake feels loose wont turn over
see if the rod fell off there is a safety switch on the clutch/brake pedals if the rod doesn't move all the way the switch will not make the connection
