Michael Fotino Posted on Sep 16, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
NAD C542 does not turn on. How to fix it? - NAD Audio Players & Recorders
Franco Dosil
Level 3:
Top Expert:
  • NAD Master 10,542 Answers
  • Posted on Sep 16, 2019
Franco Dosil
NAD Master
Level 3:
Top Expert:
Answers
10542
Questions
0
Helped
378981
Points
178965
Hi Michael, check inside your NAD C542, there are 4 fuses, check that none is open, if all are well, you could have problems with the capacitors in the area of the power supply or in the case of the Transformer
If you do not have technical capabilities to evaluate the above, consult a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
http://diagramas.diagramasde.com/audio/NAD-C542-Service-Manual-Schematics.pdf
Hola Michael, revisa en el interior de tu NAD C542, hay 4 fusibles, controla que ninguno se encuentre abierto, si est?n todos bien, podr?as tener problemas con los capacitores del ?rea de la fuente de alimentaci?n o en el pero de los casos el Transformador
Si no tienes capacidades t?cnicas para evaluar lo previamente indicado, consulta un servicio t?cnico especializada
Espero puedas resolver el problema
Saludos Franco Dosil
1helpful
My NAD C542 CD player does not turn on. What can the problem be and is there a fix?
Nad cd541i doesn't always read cd's; it can tell me how many tracks/minutes there are but won't find the beginning of the cd; in this case, sometimes if I skip forward two or three tracks and...
It sounds like a physical problem in the laser seek mechanism. Possibly a sticky area on the guides. Heavy reading for all malfunctions related to optical disc...
http://www.repairfaq.org/sam/cdfaq.htm
1helpful
I get a no disc message even though there is a disc in the machine.
Hello
there are two option of such fault
1. lens is dusty, clean the lens using moist cloth/cotton 2. lens got bad need replacement
third option is CD is faulty/scratch
hope it helps. do rate if so
Vfl display not working
no display could be a problem with the inverter circuit that drives the display
usually a transistor goes bad around the display area
check the board for dry solder joints as well
sme CD players have an option to switch off the display, check its not turned off
usually a button on the unit or the remote
darren
My NAD cd player CD slot goes in and then opens...it does not retain the CD inside to play...
Hello
This fault is due to loose tray loading belt or weak loading motor. You just change the loading belt with same type. Never use a belt more than tight. Use the same size. If belt changing does not help, replace the loading motor. OK.
How do I clean the lens? CD lends cleaner only provides temporary relief from fuzzy sound.
hi,
remove the cover, remove the spindle cover of cd player inside, thier you can see a little glas object
clean it with coton sticks and liquid that you use to clean the windows.
move over the lens gently once wet and once dry
now you lens is clean
thats all
greetings
cis
2answers
My NAD C 541 cd player will not play any discs. I open it put the disc in and it tries to scan and then rejects the disc and opens on its' own. There is the word 'over' in red below the track number...
It could be the belt for the tray mechanism. Tray closes then motor is pushed up to CD. If belt slips or physical mechanism is sticky CD will not spin and tray will reopen.
NAD CD player C 542
SORRY but you need to get this to your dealer,don,t think anything is stuck in there just a faulty drawer mecanisim.
hope this helps.
CABLE GUY.
NAD C542 CD PLAYER
maybe it is just the belt for the tray motor.
Nad plays for a minute or so...
First thing to do is to check all your new caps and their polarities.
Capital98
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
