Question about Xerox Workcentre 7345 Printer, Copier, Scanner
In Xerox7345 error code ,004-338 .is this short carkit problem?how to reset.
How to reset Parrot carkit?
my phon xt 270 wfi is a not cantg or sim cad no emergency calls only wht is tha problm
May 11, 2013 | Cell Phones
Tip
Secret Codes For SGH-600/SGH-2100
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} These are the secret Codes for SGH-600 / SGH 2100
  • *#06# -> Show IMEI
  • *#9999# -> Show Software Version
  • *#0837# -> Show Software Version (instructions)
  • *#0001# -> Show Serial Parameters
  • *#9125# -> Activates the smiley when charging.
  • *#9998*228# -> Battery status (capacity, voltage, temperature)
  • *#9998*246# -> Program status
  • *#9998*289# -> Change Alarm Buzzer Frequency
  • *#9998*324# -> Debug screens
  • *#9998*364# -> Watchdog
  • *#9998*377# -> EEPROM Error Stack - Use side keys to select values. Cancel and ok.
  • *#9998*427# -> Trace Watchdog
  • *#9998*523# -> Change LCD contrast - Only with version G60RL01W
  • *#9998*544# -> Jig detect
  • *#9998*636# -> Memory status
  • *#9998*746# -> SIM File Size
  • *#9998*778# -> SIM Service Table
  • *#9998*785# -> RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error. *#9998*786# -> Run, Last UP, Last DOWN
  • *#9998*837# -> Software Version
  • *#9998*842# -> Test ******** - Flash the screenligth during 10 seconds and vibration activated.
  • *#9998*862# -> Vocoder Reg - Normal, Earphone or carkit can be selected
  • *#9998*872# -> Diag
  • *#9998*947# -> Reset On Fatal Error
  • *#9998*999# -> Last/Chk
  • *#9998*9266# -> Yann debug screen (=Debug Screens?)
  • *#9998*9999# -> Software version
Enjoy. :)
on Dec 11, 2009 | Cell Phones
Default password of Samsung S3850
*#9998*289# : Change Alarm Buzzer Frequency *#9998*364# : Watchdog *#9998*523# : Change LCD contrast - Only with version G60RL01W *#9998*746# : SIM File Size *#9998*862# : Vocoder Reg - Normal, Earphone or carkit can be selected *#9998*786# : Run, Last UP, Last DOWN If the up Codes doesn't work, you should change *#9998* to *#0. i.e. *#9998*523# change to *#0523#. An other thing that will help is to remove your SIM card. *0001*s*f*t# : Changes serial parameters (s=?, f=0,1, t=0,1) (incomplete) *0003*?# : unknown *0003*?# : unknown
*#9998*377# : EEPROM Error Stack - Use side keys to select values. Cancel and ok *#9998*427# : Trace Watchdog *#9998*785# : RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error. *#9998*778# : SIM Service Table *#9998*947# : Reset On Fatal Error *#9998*872# : Diag *#9998*999# : Last/Chk *#9998*324# : Debug screens *#9998*636# : Memory status *#9998*544# : Jig detect *#9998*842# : Test ******** - Flash the screenligth during 10 seconds and vibration activated *#9998*837# : Software Version *#9998*228# : Battery status (capacity, voltage, temperature) *#9998*246# : Program status *#9998*9266# : Yann debug screen (=Debug Screens?)
*#9998*9999# : Software version
SP-unlock SGH-600 (and also SGH-Sgh-600 *2767*3855# : Full EEPROM Reset ( THIS CODE REMOVES SP-LOCK!! ) But also changes IMEI to 447967-89-400044-0. (Doing this is illegal) *2767*2878# : Custom EEEPROM Reset *These codes have been tested with version FLD_2C6 G60SB03X of Samsung SGH-600 Samsung SGH-600 Unlock Codes *#9999# : Show Software Version *#9125# : Activates the smiley when charging. *#0001# : Show Serial Parameters *#0837# : Show Software Version (instructions) *#06# : Show IMEI
Aug 10, 2011 | Computers & Internet
I forgot my phone lock code for a samsung s7220
For all:
*#06# Show IMEI
*#9999# Show mobile Software Version
*#0837# Show mobile Software Version (instructions)
*#0001# Show Serial Parameters
*#9125# Activates the smiley when charging
*#0523# LCD Contrast
samsung-mobiles2.jpg *#9998*228# Battery status (capacity, voltage, temperature)
*#9998*246# Program status
*#9998*289# Change Alarm Buzzer Frequency
*#9998*324# Debug Screens
*#9998*364# Watchdog
*#9998*377# EEPROM Error Stack - Use side keys to select values
*#9998*427# Trace Watchdog
*#9998*523# Change LCD contrast
*#9998*544# Jig detect
*#9998*636# Memory status
*#9998*746# SIM File Size
*#9998*778# SIM Service Table
*#9998*785# RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error
*#9998*786# Run, Last UP, Last DOWN
*#9998*837# Mobile Software Version
*#9998*842# Test ******** - Flash the screenlight during 10 sec and vibration activated
*#9998*862# Vocoder Reg - Normal, Earphone or Carkit
*#9998*872# Diag
*#9998*947# Reset On Fatal Error
*#9998*999# Last/Chk
*#9998*9266# Yann debug screen (Debug Screens?)
*#9998*9999# Software version
*0001*s*f*t# Changes serial parameters (s=?, f=0.1, t=0.1)
*0002*?# unknown Samsung's comand
*0003*?# unknown Samsung's comand
For Mobile phones SGH (R210, T100, A300...)
if Samsung code is in format *#9998*xxx#
try write in this *#0xxx#
SGH-600
SGH-2100
*2767*3855# Full EEPROM Reset (THIS CODE REMMOVES SP-LOCK! but also changes IMEI to 447967-89-400044-0
*2767*2878# Custom EEPROM Reset
Samsung mobile phone codes: Samsung E700
*2767*688# remove USER CODE and SIMLOCK
Samsung mobile phone codes: Samsung V200
Unlocking:
Power on the mobile phone without SIM card and type these codes:
*2767*63342# and press green button
*2767*3855# and press green button
*2767*2878# and press green button
*2767*927# and press green button
*2767*7822573738# press button
Phone will be unlocked, but all trims are reseted !!!
Mobile phone must be fully charged
Samsung mobile phone codes: Samsung S500
Unlocking
*2767*MVT# (*2767*688#) E2P MVT Reset
*#SIMLOCK# (*#7465625#)
Jan 15, 2011 | Samsung S7220 Cell Phone
I FORGRT MY PASSWORD IN MY MOBILE I CANNOT OPEN MY PHONE
*#06# Show IMEI
*#9998*872# Diag
SGH-600
SGH-2100
Unlocking:
Unlocking
Jan 13, 2011 | Samsung SGH-D980 Cell Phone
What is the security code for samsung SGH-D900
hi try these codes
*#06# Show IMEI *#9999# Show mobile Software Version *#0837# Show mobile Software Version (instructions) *#0001# Show Serial Parameters *#9125# Activates the smiley when charging *#0523# LCD Contrast
*#9998*228# Battery status (capacity, voltage, temperature) *#9998*246# Program status *#9998*289# Change Alarm Buzzer Frequency *#9998*324# Debug Screens *#9998*364# Watchdog *#9998*377# EEPROM Error Stack - Use side keys to select values *#9998*427# Trace Watchdog *#9998*523# Change LCD contrast *#9998*544# Jig detect *#9998*636# Memory status *#9998*746# SIM File Size *#9998*778# SIM Service Table *#9998*785# RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error *#9998*786# Run, Last UP, Last DOWN *#9998*837# Mobile Software Version *#9998*842# Test ******** - Flash the screenlight during 10 sec and vibration activated *#9998*862# Vocoder Reg - Normal, Earphone or Carkit *#9998*872# Diag *#9998*947# Reset On Fatal Error *#9998*999# Last/Chk *#9998*9266# Yann debug screen (Debug Screens?) *#9998*9999# Software version *0001*s*f*t# Changes serial parameters (s=?, f=0.1, t=0.1) *0002*?# unknown Samsung's comand *0003*?# unknown Samsung's comand For Mobile phones SGH (R210, T100, A300...) if Samsung code is in format *#9998*xxx# try write in this *#0xxx# SGH-600 SGH-2100 *2767*3855# Full EEPROM Reset (THIS CODE REMMOVES SP-LOCK! but also changes IMEI to 447967-89-400044-0 *2767*2878# Custom EEPROM Reset Samsung mobile phone codes: Samsung E700 *2767*688# remove USER CODE and SIMLOCK Samsung mobile phone codes: Samsung V200 Unlocking: Power on the mobile phone without SIM card and type these codes: *2767*63342# and press green button *2767*3855# and press green button *2767*2878# and press green button *2767*927# and press green button *2767*7822573738# press button Phone will be unlocked, but all trims are reseted !!! Mobile phone must be fully charged Samsung mobile phone codes: Samsung S500 Unlocking *2767*MVT# (*2767*688#) E2P MVT Reset *#SIMLOCK# (*#7465625#)
May 15, 2010 | Samsung SGH-D900 Cellular Phone
I need to unlock the network lock for samsung sgh l810i
hi try these codes
May 14, 2010 | Samsung SGH2100SGH600V300 Unlock/Unlocking...
I need to no the unlock code for a samsung e1120
hi try these codes
May 12, 2010 | Cell Phones
Phonelock
Hi try this
r all: *#06# Show IMEI *#9999# Show mobile Software Version *#0837# Show mobile Software Version (instructions) *#0001# Show Serial Parameters *#9125# Activates the smiley when charging *#0523# LCD Contrast
May 13, 2010 | Samsung SGH-J600 Cellular Phone
I had forgotten my samsung metro 3310 app codes
hi try these codes
May 11, 2010 | Cell Phones
Xerox Workcentre 7345 Printer, Copier, Scanner Logo
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
