Question about Xerox 6505/DN - Workcentre 6505dn Color Laser Mfp,
Xerox WorkCentre 6505 DN duplexes over usb but not over ehternet
Windows 10 os on ethernet can't get duplex to work windows 10 over usb duplexes
SOURCE:
  • 141 Answers
SOURCE: stopped duplex printing when updated to Vista
Check for new drivers(for your printer) or upgrade, for windows vista....Sometime the driver for windows xp is not the same.
Posted on Mar 25, 2008
  • 21 Answers
SOURCE: Getting the Duplex Attachment to Work with Vista
what printer do you have?
brand and model?
do you has installed the newest driver and utility for vista operating system?
do you know that Vista and XP are incompatible in terms of drivers?
Vista has many drivers for a lots of printers, but these drivers are "generic driver". The generic driver is a small driver, an incomplete driver, and has a limited functions.
Posted on Sep 24, 2008
SOURCE: Duplex printing from Windows 2003 does not work.
some mnfs drivers require you to web into the copier (type the printer ip into interntet explorer) and turn on certain features like duplexing and finishing options before you can use them in a drop down print property page such as word.
Posted on Aug 04, 2009
1alexh
  • 484 Answers
SOURCE: When on my pc i
You covered half the equation. Now, contact D-Link for their half. No joke. They are usually available 24/7, and will gladly help you, especially if your d-link product is still under warranty.
Tell them everything, all your settings, and so on, then ask them if they would like to remote into your system for a chance to poke around and see if they can fix this for you.
This is also something that they will happily do, if you invite them in, and that way, you can watch them and learn while they help you fix the problem.
-a.
Posted on Dec 18, 2009
Testimonial: "thank you so much, i will contact d link and let you know what happened thanks."
  • 41 Answers
SOURCE: I have HP 2015dn printer. In Windows XP I can
use this driver in rar
Posted on Mar 27, 2010
What does jam bottom duplex means
Hi the main problem for wc3635 and wc3550, when copier is showing that Jam is in duplex is the broken duplex sensor lever Change the lever and problem will be solved.
Jun 24, 2014 | Xerox WorkCentre 3550
Scan documents on the 6505/DN using my pc or mac, what do I need from xerox
copier/scanner should do the trick and the new product will contain all the equipment.
Oct 17, 2013 | XEROX - COLOR PRINTERS 6505DN 6505/DN...
Can't print duplex on p2015d with pcl6 driver on windows 7 Only allows manual duplex with universal print driver pcl5 and pcl6
Hello, not all of the P2015 Series printers support Automatic Duplexing. Are you sure you have the correct model printer? Only the P2015D/DN/X support this feature. Check the front cover, it will have the model listed... In the printer driver, check the device settings, see if duplexing is an option and enable it.
Jan 15, 2011 | HP LaserJet P2015d Printer
Phaser 5500 will not duplex
its definitely a driver related issue.....download latest driver from www.xerox.com
Nov 09, 2009 | Xerox Phaser 5500/DN Laser Printer
Aug 04, 2009 | Office Equipment & Supplies
HP PRINTER
isnt an 8500 dn a Xerox printer??
Sep 19, 2008 | Office Equipment & Supplies
Printing recto verso
On your computer, click mouse on windows icon in lower left corner of screen. When the menu appears, left click on 'printers'. Go to the icon representing the Xerox, and right click mouse. from the drop-down list, chose 'properties' at the bottom. The 'properties' window should appear. Under the ''general' tab, it should show 'yes' for double sided prints. Go to the 'accessories' tab and left click mouse. A list of installed accessories should appear. See if there is a 'duplexer' accessory available. If it is, left click on the duplexer display and add it to the Xerox. Left click mouse on "apply" tab, then left click on the "OK' tab. Exit out of 'printers' and test.
Jul 05, 2008 | Xerox WorkCentre M123 Copier
Xerox 6505/DN - Workcentre 6505dn Color Laser Mfp, Logo
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
