The only way I have found to seal those tops back down is with 100% silicone caulk, NOT LATEX OR BUYTAL, silicon.( We use 3m.) Then hold it down with cinder blocks for at least 24 hours then you are in business.
Most evaporator fans run all the time. This is mainly to use the air flow to assist in melting off any frost build up during the compressor off cycle. If that fan shut off with the compressor the coil will have a tendency to freeze up. :)
It can take a very long time to get a keg of beer down in temperature. The heat transfer from a keg is slow due to the lack of air circulation inside the keg. You should also check your condenser coils, make sure they are clean. Door gasket should also be in good repair. Hope this helps.
electrician do one thing, electricity. If the unit cools, the compressor is running. a power outage should not put the compressor in a "Weaken" state. I would check the starting components. don't overlook your surge protector causing a voltage drop. try running the unit without the protector.
let me know if I can be of any further help.
