SOURCE: I need the instructions for
It is fairly complicated, but luckily I found the manual for the device that goes into detail on exactly how to descale it. You want to go to page 8 of the manual. I will provide the manual at the end of my answer here...
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
http://www1.nespresso.com/precom/sav/pdf/HD_RO_en.pdf
Thanks
Tim
SOURCE: Nespresso Magimix M250. power button pushed back into housing, How to access switch?
to get at the button you need to undo the two screws and the top and the two security screws on the front panel. The security screws are oval. I made up a tool by drilling an appropiate size hole in a bit of bar and then widened it out by angling the drill slighty to make an oval. once you have these out then you can tatake the front pannel off. the swithches are attached to the back of the front panel so watch out for the power cable. You will then need to take the switch housing off - a couple of torx screws and then it unclips. the button is on a hinge at the bottom and a prod to an electrical switch behind. I fixed mine with some flexable adhesive but it wont last Nigel
