Question about Pentax Cameras
Hi i have a pentax espio 115 film camera. It opens but the zoom lens isnt and when i click any button it makes clicking noises and the display shows "UF" code. What does it mean?????
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 2985 Answers
SOURCE: zoom lens not retracting
May be a bit of grit gas got in. Do not try to manually manipulate it- this will wreck the motor drive. A Vacuum clean suck way have some affect. Certainly contact Pentax Tech Support Team .
Posted on Jul 02, 2007
The Machine
Dean Joly
  • 788 Answers
SOURCE: Automatic lens cover only shuts
My Kodak does the same way the kids got there sticky fingers on it.
I would suggest trying to clean it with some 98-99% Isopropyl Alcohol since the alcohol evaporates completely. Make sure to remove the batteries before doing it. Also use some compressed air to try to dislodge any dirt, dust, or debris that may be stopping the movement.
If it still doesn't close once you've cleaned it then there may be something physicaly wrong or broken inside the camera. You can attempt dissasembly but it could be quite fragile and tricky to take apart and even more so to put back together.
Otherwise, always keep a good clean micro-fiber cleaning cloth with you and clean the lens frequently.
Posted on Jun 23, 2008
ftw1952
frank thomas wilson
  • 10319 Answers
SOURCE: pentax camera espio 738g zoom
The camera has a faulty capacitor inside the circuit board. Having it repaired generally cost more than purchasing a replacement camera. Capacitors store the power needed to operate motor drives when needed. If they get a hairline crack on the outer shell they will lose there ability to operate correctly such as yours is doing
Posted on Jan 02, 2011
siladityaa
siladityaa
SOURCE: U7 error code when Pentax Espio 200 camera
Its actually a technician code which means that your Zoom system has malfunctioned. If you want to remove the film then you can simply click the reset button and then remove the film. If you want to get it repaired then it would be better if you throw it and look for a new SLR Camera
Posted on Dec 01, 2012
I need a user Manual for ESPIO 160 Pentax camera
The ESPIO 160 is called the IQZoom 160 in some parts of the world. You may download a copy of the IQZoom 160 manual here.
May 31, 2012 | Pentax ESPIO 160 QD 35mm Film Camera
I was given a 35mm pentax espio 70 zoom camera recently but I have no instruction leaflet with it. Is it possible still to get one.
Most documentation is available online. Use the search engine of your choosing to look for:
Camera manufacturer + model + manual
I believe you can find it here:
http://www.pentaximaging.com/support/manuals-and-literature/
Feb 28, 2011 | Pentax Espio 738S 35mm Point and Shoot...
U7 error code when Pentax Espio 200 camera switched on. What does it mean? Can I rewind and remove film to develop?
Oct 22, 2010 | Pentax Espio 200 35mm Film Camera
I have a problem,on the display blinked code U7L?
Hi! Try removing the battery and press hold the power button for 10secs. while the battery is removed. This will reset the system and resolve the problem. Hope this helps and thank you for using FixYa!
Oct 07, 2010 | Pentax Espio 140V 35mm Point and Shoot...
Camera suddenly stopped responding, maked grating noise and shows HI in window. wil not turn off.
If the 'H' disappears when the zoom lever is moved the camera is ready for use. If the 'H' appears often, it should be taken to the service.
Nov 20, 2009 | Pentax ESPIO 160 QD 35mm Film Camera
On the lcd it shows "E" "E 9" and I do not know what this means and the camera will not work. What needs to be done
This question has been answered repeatedly. Pentax error codes are mostly for camera repair technician diagnosis and most of the time mean the camera is broken and needs professional servicing. Some Pentax Error Codes:
E: "E" often indicates a film jam. This code can appear when the film is inserted incorrectly, when the batteries are changed in the middle of a roll of film, if you are using defective film, etc. If "E" appears in your camera's information display, try to rewind your film manually (see your user's guide for instructions on how to activate your mid-roll rewind function), and try a different roll. If this problem keeps occurring, you might need to send the camera to us for repair.
E3, E7, E37: These codes often signal a problem with your shutter mechanism.
E9, E93-E97: These codes may indicate a problem with your zoom lens.
H0-H9: These H codes can also identify a problem with your camera's shutter.
U1-U9: These U codes may also indicate a problem with your camera's zoom lens.
These codes are standard for both Digital and film cameras.
Please rate our helpfulness to keep the service viable++++Thanks for using FIXYA
Sep 22, 2009 | Pentax Zoom 105-R Film Camera
Shutter permanently open and zoomed. will not close in even without battery. tried new batteries, no change
It needs factory repair - find another used camera or buy a new digital. That camera is not worth spending the money on to repair.
Aug 10, 2009 | Pentax Espio 115V 35mm Film Camera
Pentax espio 140
subaru662,
can you see the lens in the finder move when you zoom out? if not ,the finder lens is stuck.
if it does move when zooming, see if you have a diopter adjustment wheel or sliding knob near the front lens of the finder. if so adjust the lens to your eye.
Jun 28, 2008 | Pentax Espio 140V 35mm Point and Shoot...
Pentax Espio 115 exhibits an H3 error and camera does not work. Sometimes it's a H2 or 1 error. What does this mean.
RE: Pantax ESPIO 115
Dear Sirs,
I bought the Pentax espio 115 Camera in Tokyo and have been well using but it was out of order suddnly .I could find in Lcd panel appeared <H3 mark>and not worked after.
Kindly let us know as quickly as possible what should I do shoot the trouble..??!
Awaiting your kind response.....
Thank you.
Mr.U.S,Yu?South Korea
email:elvisu@lycos.co.kr
Mar 21, 2008 | Cameras
Zoom lens not retracting
Jul 02, 2007 | Pentax IQZoom 140M 35mm Point and Shoot...
Cameras Logo
42 people viewed this question
Top Pentax Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
