Google doesn't recognise those numbers, I believe you will need to state the make and model of the device you need the power supply/AC adaptor for.
An original type would be better for an expensive device as the aftermarket power supplies are of rather mixed quality and there is a possibility an overload might occur and damage the device or in the case of a switch mode type of adaptor, some cheaper types can have important interference suppressors left out.
An original type can only be sourced from the device manufacturer but these are usually unjustifiably expensive, otherwise both Amazon and ebay among others will supply compatible items of all sorts.
SOURCE: 12 DC ADAPTER
Try looking for a Jensen JE2043 with identical specs for the adapter: Input :100-240VAC (50-60Hz); Output : 12Vdc 6Amp. You can try ebay .
Alternately a 13.8/6A regulated power supply for communications equipment would also work. You simply need to hardwire the crown plug and red/black wires.
Good luck and kind regards.
SOURCE: Need motor brushes for ASKO 12505 washer.
Here is one location to look at.
http://www.repairclinic.com/Appliance-Parts?s=t-12505%20-%3d%3d
SOURCE: I own a McCulloch Model FH130B Hi Pressure Jet
A real good/knowledgeable hose shop in your area should be able to fab a replacement. Otherwise possibly check at a local contractor store like that of home depot for replacement short of investigating the mfg web site for authorized repair/service centers in your area.
SOURCE: need a new SEL AC Adapter Class 2 Transformer Mode...
You can order the transformer from Black and Decker either online or you can go to one of their Service Centers located around the country.
Vector sold all of their prodduct line to Black and Decker in 2006.
SOURCE: I need an AC 12v-5v powr adapter for a PROSCAN TV.
USE a simple laptop adapter thats whhat i did just tell the guy at local comp store 12 volts and 5 amps they should have 1 or able to order it also try a used comp store they abound on craigs list and kijiji canada
