SOURCE: Need to change the light bulbs
The light shield has two tabs, one on each side. They may be on the front or back of the shield, It fits either way. Pull the tabs down and slide the shield back and forth a couple of time and it should drop from the four pegs that hold it in place. You will have access to the bulbs. You can go to http://www.subzero.com/locator/locator.aspx?type=0&zip=02030 and find a parts distributor near you or take a bulb to the store and match it. Make sure you get the same wattage rating.
SOURCE: sub zero 690 the control lpanal light does not come on
If the refrigerator is working fine, you may have a bad door-switch. Open the refrigerator door, you will see two switches on top, the one on the left is for the lights; try to tweak it may just be stuck. If this does not work you have to replace it. You can double-check this by shining a flashlight behind the control panel and you can see the temp. and the other info. This means the panel is fine. You can also try to contact Sub Zero customer service, they may send you a new switch for free.
Good luck and I hope this help.
Byron12020
SOURCE: Sub Zero 690 replaced lights but fan and lights dont work
The fan will only run when the compressor is running. Check it a couple of times to see if it actually is not going on. There is alos a light terminator located behind the fan cover. We will assume it is the light switch. For the light switch go to http://subzero.com/locator/locator.aspx?type=0&zip=Zip%20Code. This will take you to a locator to find the authorized parts distributor for your area I believe the part number for the light switch is 3060140 have them check it using your model and serial number. Once you have the part remove the three phillips head screws that hold the grill in place, this is assuming you don't have the louvered grill. You access these inside the fresh food and freezer compartments. With the door open you look up in to the metal you will be able to see them. Once you get the grill off there is a grey power cord with a white quick connect disconjnect this or turn the power off at the circuit breaker. You will be working on live electricity if you don't.Not good for your life expectancy. There is one more phillips head screw for the cover of the two switches. The light switch has a white back and the fan switch has a black one. Remove the two wires then push it down and slip the new one in. Replace all that you took off. While you have the grill off vacuum the condensor. If this is too much the link above also is for authorized service in your area.
SOURCE: 8 year old Sub-Zero model 690. Condensor coil leaking
When copper and aluminum are connected it cannot be welded, it has to be crimped. this is a problem that is not exclusive to sub zero, an all aluminum evaporator ( if it is in the refrigerator it's an evaporator) should resolve the problem nicely
SOURCE: Sub-Zero 690 Side by Side Refrigerator light switch intermittent
This is a common problem - replace the left light switch with Sub Zero Part # 3060140.
