Question about Watches
My oxywatch won't turn on. I have replaced the batteries.
    Top Expert:
  • Watches Master
  • 54,189 Answers
  • Defective "new" batteries
  • Incorrect installation
Posted on Sep 15, 2019
SOURCE:
I have a 95 honda civic ex,wont start.ran fine yesterday,wont start this morning.battery is fully charged,new cap and rotor.would do u think might b my problem
if it wont turn over 1st check the ground s on the car and the battery 1st. your battery can be fully charged and the car will not start even over night this can happen. then look at the starter. Note: if you have over 109K on the car and the timing belt has never been replaced you will need to have this checked as well.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tom_db3a51ff0ca57f20
Aug 16, 2014 | Cars & Trucks
Transporter turns over but won't catch
the fuel is proberly stale drain tank and replace
hope this helps
John
Jun 15, 2013 | Volkswagen Transporter Cars & Trucks
Watch won't work after changing battery
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs..
Apr 20, 2013 | Watches
Might have water damage but power is off and won't turn on
Can u change the battery and see if that was the issue? If so and its not the battery you could open the watch on visibly check for black/scourched marks that would indicate that (probably the water) something has shorted said part(s) with the marks. If you see nothing strange then its time to use a meter to test parts.
Mar 31, 2013 | Watches
My 1991 Ford Tempo won't start. It turns over but doesn't spark. The battery has been replace, checked fuel pump and spark plugs but it still won't turn on. Help?
change the ignition pick up coil assembly normally located on the distributor under the rotor on the bottom of the distributor or just replace the distributor
Jan 30, 2013 | 1991 Ford Tempo 4 Door
My 2008 silverado won't start battery is charged
No, it isn't an ignition issue.
Check power to the starter motor solenoid.
If this is getting power when cranking, then the issue is with the starter motor solenoid or starter motor. Replace.
Nov 12, 2012 | Cars & Trucks
Why would a tissot t-touch need an overhaul to replace a dead battery
These babies are notorious for going down the tubes with a battery change. I bet if you get it back it won't work with a new battery. Twice I have replaced batteries and the watch didn't work when I finished. One of them was my own watch, I think $450 is about half the price of a new watch and that is sad. Cool watch just not very long life
Oct 01, 2012 | Tissot T-Touch T33759851
My Sportline won't zero the steps
find your watch off this link below click on it and download the manual
http://www.sportline.com/products/heart-rate-monitors.html
Sep 20, 2012 | Watches
New watch won't start
Maybe the battery is bad? If its new take it back to where ya bought it and tell them. Most places will replace of fix it. I would check the battery.
Aug 11, 2012 | Armitron Watches
2004 buick rendezvous sometimes won't start. clicks but won't turn over. replaced starter, battery, and ignition switch. what now??
We just went through this with our 2003 Rendevous. Clicking like crazy but wouldn't start. Replaced the starter but still doing the same thing. Our next step was going to be replace the battery (which tested well) and the ignition assembly. Out of frustration, I hit the top of the hood and the headlights came on!! Further investigaton proved that the problem was a corroded ground wire on the battery. Hope this helps
Aug 06, 2012 | 2004 Buick Rendezvous
Watches Logo
109 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
