SOURCE: moen kitchen faucet set wsprayer can't shut sprayer.
there is always water pressure on the sprayer when water is on. if sprayer is leaking check if trigger is stuck in . best to just change the sprayer handle it comes off at the base of the handle
SOURCE: HOW TO DISMENTLE OR REPLACE A MOEN SINGLE LEVER
shut water off at stops under sink. Unscrew water supply lines from directly below handles. Above them you will find plastic nuts, remove them. Disconnect pop/up lever and you should be able to lift faucet from sink.
SOURCE: how do you take a moen bathroom Model #:
On the handle it self you should see a red and blue button plug. Remove this and you will see set screw. Remove handle, remember to shut off hot and cold water supplies under sink before you go any further.
SOURCE: leaky moen 2 handle faucet
if memory serve's me,you will need to remove a stem extension,screw in center,and you may need a tool #103462 to remove cartridge.1'st stem ex't is red,(hot) blue (cold), remove, look down,white piece w/ 2 notch'es, this hold's cartridge down, ya might try needle nose plier's to remove,a little lube help's upon re assembly, carefull w/plastic thread's
SOURCE: how do i replace gasket on moen facuet in bathroom
On a Moen Faucet the set screw is behind the little "blue and red plastic tab", remove this tab very carefully with a small flat screwdriver. Then you should be able to see the set screw. make sure to turn of the water supply under the sink first. The set screw will probably be an "allen head" type and you will need an allen head wrench. This is a hex shaped 6-sided tool in a rod shape and is available at your local hardware in a set. Next you will need the model # of your faucet and take this to your local hardware to match with a repare kit. Moen usually has a lifetime warranty and if you have your paperwork just call Moen directly and they will send you a free replacement kit, free shipping too. The kit has installation instructions with it.
