Question edited for clarity and typos.
The Bluetooth isn't correctly paired. You are only half connected.
https://www.fixya.com/support/r26362721-pairing_bluetooth_devices
STEPS FOR CONNECTING WITH BLUETOOTH DEVICE Once paired you can play music from your Bluetooth device. You can also use the control buttons on the unit to select the tracks from your Bluetooth device.
1. Press MODE button to choose Bluetooth mode, display BLUETOOTH on the screen.
2. Search on the Bluetooth device name from others Bluetooth device and you can and the Bluetooth name - PYLEUSA
3. Select the PYLEUSA Bluetooth name and wait for the device to pair.
4. The PTA44BT will emit a noise confirming that the devices have successfully paired..
PTA44BT
Pyle USA
http://manuals.pyleusa.com > PDF > PTA44BT
PDF
PTA44BT. 4 Channel Audio Amplifier. Multi-Source 1/4" Audio/Microphone inputs ... PyleUSA.com ... Read these instructions thoroughly before using this item.
9 pages
PYLE PTA44BT USER MANUAL Pdf Download ' ManualsLib
ManualsLib
https://www.manualslib.com > ... > PTA44BT
View and Download Pyle PTA44BT user manual online. 4 Channel Audio Amplifier. PTA44BT amplifier pdf manual download.
